1982 factory positraction differential...what kind of lubricant do I use ?please help
Old Nov 24, 2012 | 08:19 AM
greekknight's Avatar
Hey guys I need some help
In a 1982 factory positraction differential what kind of lubricant do I use?
Is there a special lubricant for posi differentials or a regular lubricant with some additive?
Thanks in advance for your reply
Old Nov 24, 2012 | 08:29 AM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
Re: 1982 factory positraction differential...what kind of lubricant do I use ?please
"Standard 80-90 weight and a friction modifer (GM P/N 1052358) if the limited slip is an Auburn.* A Gov-Lock or open/standard differential doesn’t require the additive. The rear holds approximately two quarts of gear oil.
*Though some TGO members use a full synthetic, such as Mobil 1 75-90, along with the above friction modifier, both Auburn and Eaton do not recommend synthetics for usage with their limited slips."
from JamesC sticky FAQ on 10 Bolts
Old Nov 24, 2012 | 09:51 AM
big gear head's Avatar
If you have the Auburn then you might need to add 2 bottles of the oil additive. Use one bottle first and see how it works. If it pops when you turn corners then put in another bottle of the additive. Most of the 4th gen cars with the Auburn need 2 bottles of the additive, but I haven't had any problems with using one bottle in the 3rd gen cars.
Old Nov 24, 2012 | 02:18 PM
Thank you!
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
