700r4 problem
Old Dec 12, 2012 | 06:43 PM
RLibby11's Avatar
700r4 problem
Hey guys, I'm new here and love this site.
I have a 1984 z28 I have been bringing back to life. It has just under 25K original miles on it. It had been sitting for a few years and after changing the fluid in the transmission it shifted hard and was very delayed.
Let me run you through what has happened. From 2nd to third it is a very hard shift and very delayed like it wants to shift but it won't until it is around 4500 rpm. Then in third to fourth it seems to shift fine but is delayed. The weirdest part is that when you really get on it, it shifts perfect. Now when we changed the fluid the old stuff was fine. We also put some cleaner in it that seemed to make it a little better but not much.
From what I have read on here it might be the T.V cable? but I'm not sure. I would like any help or suggestions I love this car and plan to put in a 350 or 355 in it soon. So my question is should I replace the whole transmission or rebuild it? or could I simply drop a th350 in it? Or is it just a simple fix that would save a ton of money?
Thanks,
Riley
Old Dec 12, 2012 | 08:08 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Re: 700r4 problem
I'd try adjusting the TV cable before pulling the trans.
Old Dec 12, 2012 | 10:44 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 700r4 problem
i had a simuler problem with my old 84 ho z28.the problem was that all the teeth on the governor wore off.
Old Dec 13, 2012 | 08:51 PM
RLibby11's Avatar
Re: 700r4 problem
Thanks I will try to adjust the TV cable and then if that doesn't work then I'll have to yank it out and try to see whats going on
Old Dec 14, 2012 | 07:33 PM
C409's Avatar
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
Re: 700r4 problem
........... Check the governor ... its easy enough to get at without pulling the trans ............. make sure its not sticking in addition to checking the drive gear ....................
Old Dec 14, 2012 | 07:36 PM
JoeyG's Avatar
Car: 68 Chevelle w/ TPI, 87 Formula 350
Transmission: 700 R4
Axle/Gears: 3.55 / 3.42
Re: 700r4 problem
Both of these are good suggestions. Try them. Try the cable first.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
