minor problem? help needed
Old Dec 21, 2012 | 10:03 PM
Kurtis32's Avatar
Car: 86 camaro coupe
ok today i started my car for the 1st time in about 5 days, i let it warm up a few minutes since it was kinda cold. well wen i shifted from park to reverse my rear tires squealed real quick as if i stepped on the gas and break. does anyone know wat would cause that? its been cold and she doesnt perform well in cold weather and being a week since i started the car im sure didnt help. any info would be great
Old Dec 21, 2012 | 10:36 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: minor problem? help needed
The TV cable might need adjusted. Your 305 should run it's best in cold weather with 91 octane.
Old Dec 21, 2012 | 10:48 PM
89rs454's Avatar
Car: 1989 SS
Trans Fluid might be low.
Old Dec 21, 2012 | 11:01 PM
Kurtis32's Avatar
srry i shouldve mentioned its carbureted, and the trans fluid is fine, anything else?
Old Dec 22, 2012 | 01:44 AM
89rs454's Avatar
Car: 1989 SS
you must have skipped over TV cable.
Old Dec 22, 2012 | 01:46 AM
89rs454's Avatar
Car: 1989 SS
Or just a pos transmission.
Old Dec 23, 2012 | 01:47 AM
Kurtis32's Avatar
oh alright, thanks for the info man
Old Dec 23, 2012 | 01:56 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Did you tap the throttle to get it off high-idle? It sounds like it may have been idling a little high. No biggie.
Old Dec 23, 2012 | 01:52 PM
Kurtis32's Avatar
yea i did actually, let it warm up a few minutes and revved it a few times, then put it in reverse and the tires squealed real quick. its never shifted smooth going from park to reverse or reverse to drive. gears shift fine while driving tho
colton_carlson
Mar 8, 2019 12:21 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
NBrehm
Aug 5, 2015 07:57 PM
