I can not allign t5 with engine & (Am losing My Mind)
Old Jan 13, 2013 | 03:44 PM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
just finished doing a rear main seal and oil pan gasket change,, i have the engine lifted on 3 inches of wood blocks on the mounts. i had took the tranny out also, reason being to get clearence of the pan hitting the fly wheel. now after ive done the job i needed to do. i alligned the fly wheel back up ,the clutch and pressure plate with allignment tool, and bell housing, hyrdaulic clutch release cylinder and pivit. i lift the tranny up to put it in but the mother ****a wont even budge. i dont know what else to do cause ive tryed puting it in 100 times. any of yall got tricks for this.. ive been trying to think wether i shud take the fork linkage off the pivit to take pressure off the throw out bearing. cause i feel like thats giving me a tough time sliding over on the main shaft. does your fork move when its in there ? . and you know what maby i did pass it or not and just didnt go through the splines. but yeah, please do post your thoughts cause my brain is ****in deteriating.
Old Jan 13, 2013 | 03:46 PM
yayoWHITESACK's Avatar
Car: 1987 z28 all stock + tricked 85 z28
Engine: 388 stroker + Procharger D1SC
Transmission: TKO 600
Axle/Gears: richmond 3:73, EATON, moser shafts
Re: I can not allign t5 with engine & (Am losing My Mind)
get a lift its so much easier i have a max jax half lift its plenty of room under the car for tranny removal
Old Jan 13, 2013 | 03:51 PM
tzim350HO's Avatar
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
You have to remove the bellhousing from the tranny and put it on the engine first! Ive ran into this before! Much easier
Old Jan 13, 2013 | 03:54 PM
tzim350HO's Avatar
Engine: 350 carbed
Once you do that its a breeze. just make sure you have the clutch plate lined up good and it will slide right in. dont forget to lube the pilot bearing in the end of the crank while your at it
Old Jan 13, 2013 | 03:56 PM
Shep5B's Avatar
now theres the problem. the bell housing is on the engine.
Old Jan 13, 2013 | 03:57 PM
Shep5B's Avatar
as of now. so that couldnt be it
tzim350HO's Avatar
Engine: 350 carbed
Bolt the engine back up to the motor mounts and let it rest backwards! If you exhaust is still hooked up it help keep it from going back so far it smashes something against the firewall
Old Jan 13, 2013 | 03:59 PM
Shep5B's Avatar
my manifolds are out of the car. i had to drill the studs out . so that aint a possibility for me
tzim350HO's Avatar
Engine: 350 carbed
the engine has to sag backwards to get that tranny back in there. If you have already removed the distributor cap or distributor you might have to
Old Jan 13, 2013 | 04:02 PM
Shep5B's Avatar
yo but all that is out. its tilting way back as it sits on wood blocks. put it this way, it touches the engine touches the fire wall, (( when u had to put your t5 in what did you do step by step) ) .. but like i said before, did your fork wobble a bit
Old Jan 13, 2013 | 04:07 PM
tzim350HO's Avatar
Engine: 350 carbed
I didnt hold the engine up with anything but i still had my exhaust attached. I made sure the pressure plate and clutch were lined up properly. Bolted the bellhousing up, with the fork on the bellhousing with the bearing installed on the fork. then the tranny would slide right in, just make sure to fit that bearing over the end of the shaft on the trans as best as you can while sliding it in there. Stupid question..... You did use the alignment tool on the clutch plate right?
Old Jan 13, 2013 | 04:09 PM
Shep5B's Avatar
lol yes. the 26 spline 1 1/8 diameter tool.. i did that and torqued every thing to specs and its still some bull sht
Old Jan 13, 2013 | 04:11 PM
tzim350HO's Avatar
Engine: 350 carbed
Its gotta slide right in there unless something is just off. i know its aggravating. I didnt mean to stomp on your toe but you never know who you might be dealing with!! LOL (WHAT TOOL)
Old Jan 13, 2013 | 04:14 PM
tzim350HO's Avatar
Engine: 350 carbed
Ive had my transmission out probly 7-8 times in the past 3 years ive owned the car and its been the same way every time since i figured out the sweet spot. Drag racing = lots of clutch changes!
Old Jan 13, 2013 | 04:15 PM
Shep5B's Avatar
na its cool . i dont take none of that personal. but its just truly weird that my t5 wont slide in. i made sure all my marks from the pressure plate to the fly wheel were correct and i use that allignment tool for the clutch to make sure sht like this wouldnt happend
Old Jan 13, 2013 | 04:17 PM
Shep5B's Avatar
damn thats a hell of alot swaps. its to bad i aint got that sweet spot. right now am finding nothing but dog sht lol
Old Jan 13, 2013 | 08:13 PM
Shep5B's Avatar
yo i dont know wether i did it right or wrong, but i unbolted the release cylinder bolts for the fork and let the release bearing ride free. i put the tranny on and went through till it stoped at around an inch or lower. i bolted the 2 top bolts by hand. then went to the back of the tranny and put the tranny mount and crossmember bolts on. then i went and put the bolts by the release cylinder. then tighten the 4 bolts on the tranny from a inch ah way. am not sure how dis tightened but it did, hopefully my out come when i start it aint to bad.
Old Jan 13, 2013 | 08:46 PM
gp90gta's Avatar
Car: 1990 GTA
Just a question but did you by any chance put lube or anything on the pilot bushing, I once put wheel bearing grease in the pilot bearing (a little to much) and the mother wouldn't go in for nothing, was causing an air barrier and pushing the input shaft out no matter how hard I tryed to push it in.
Old Jan 13, 2013 | 08:51 PM
tzim350HO's Avatar
Engine: 350 carbed
I didnt know you had the slave cylinder bolted up. Thats why you were having so much trouble. The reason you had to tighten the bolts to draw the tranny up to the bellhousing all the way is just because of the tight fit in the pilot bearing. (Bushing in the back of the crank) It should be fine! Ive had to do the same thing with mine a few times. Sometimes they will slide right in and other times you have to draw them up with the bolts. glad you got it!
Old Jan 14, 2013 | 06:10 AM
Shep5B's Avatar
thanks for the help..
Old Jan 14, 2013 | 06:12 AM
Shep5B's Avatar
yeah i put a little grease on everything, but not to much. so i couldnt even tell you why it made it so hard to go in.
Old Jan 14, 2013 | 08:32 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Pull the slave off and you should be good to go. If you still can't get it, put up some pictures of how it is setup and I'll try to help!
Old Jan 14, 2013 | 07:57 PM
Blk91Firebird's Avatar
Car: 91 Firebird, 89 Bird, 86 Bird
Engine: None, 5.7, 5.0 L.O.
Transmission: None, T5, Thm 350
Axle/Gears: 3.23, 02' 3.43 rear disc, ???
Sounds like you figured it out but last time I went to put my t5 in I fought and fought with it then My wife came out and got in the car and was talking to me while I was trying to get it in, she absent mindedly pressed the clutch pedal and the tranny slid right in.
Old Jan 14, 2013 | 07:59 PM
tzim350HO's Avatar
Engine: 350 carbed
I never do it that way. It's too easy to damage the throw out bearing. All that matters is its in there now!
Old Jan 15, 2013 | 04:04 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
this was going to be my recommendation.. those craptastical plastic alignment tools are junk and the clutch disc almost never winds up in exactly the right spot... so either get a good metal alignment tool or get an input shaft out of a junk trans and use that to line up the clutch.. then when you go to put it in, if it won't go that last little bit just hook all the clutch stuff up and have someone push in the clutch while you wiggle things around.. they generally slide right in..
F-body driver
Feb 7, 2015 11:24 PM
91_5.7_TPI
Jul 20, 2014 04:14 PM
onebinky
Jan 5, 2004 09:24 PM
PONTIAC86style
Nov 29, 2003 02:45 AM
