Advice on drive shaft needed
Old Jan 16, 2013 | 11:08 AM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
Was about to put the drive shaft back on last night and noticed a potential problem at the rear end of the shaft coupling pieces (I don't know much about drive-shafts, so excuse my wording here).
On one set of rotating caps, there is a piece of metal that join the two rotating caps together. That piece of metal is very thin and has become detached from one site of those caps (see picture).
Does that mean that it will now not work propery, or should I just line up those caps and bolt it on to the diff and not worry ?
Rhys
Old Jan 16, 2013 | 11:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Advice on drive shaft needed
Completely remove the metal strap. It is only an assembly aid to prevent the caps from falling off while the driveshaft is out of the car.
Be sure to clean the caps and where they seat in the yoke. Just don't knock a cap off while doing it. A quick by-hand wire brushing should do the trick.
RBob.
Old Jan 16, 2013 | 01:47 PM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
Thanks again Rbob.
I really do not have much experience with rear wheel drive cars.
Will clean the caps carefully.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
