700r4 shifter cable won't stay adjusted
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
I have adjusted my shifter cable several times only to have it change after only a few shifts. I'm wondering if I have the wrong nut on it, or possibly the teflon washer is somehow not on the linkage correctly. Does anyone have a pic of the proper assembly?
Can't seem to figure what I'm doing wrong here.
Thanks in advance for any suggestions!
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: 700r4 shifter cable won't stay adjusted
Car: 86 coupe
Engine: 383
Seems to be OEM. It was ok before the engine swap, which leads me to believe I did something wrong.
That bracket that holds it at the trans is kind of flimsy, but the cable is visibly sliding in the trans linkage slot. The assembly gets torqued to spec and then after maybe 5-10 shifts it has slipped enough that the nut/bolt/washer have moved to the front of the slot.
Engine: Modded L98
The factory shop manual, for my 1991 model, says, 'put the stick in the neutral postion, put / rotate the transmission lever to the neutral postion, install cable and tighten nut.' That has always worked for me. The only time I had a problem is when some hack-shop worked on my car, and installed an aftermarket cable. After about 1000 miles of use, the a/m cable was toast (wouldn't go into park); when I went to adjust it, I discovered it was an a/m cable, and it would not stay adjusted. I got a used OEM cable, installed it per the instructions above( NO 'ADJUSTMENT' REQUIRED), and it worked perfectly.
Car: 86 coupe
Engine: 383
The cable isn't stretching, the nut/teflon washer/shouldered bolt assembly are slipping on the linkage.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
db057
Aug 11, 2015 10:11 PM
