Shifter Lever Damper
Old Jan 25, 2013 | 03:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the plastic/nylon damper is broken and severely worn, what are the symptoms (I have a buzzing in that general area at low speeds that i'd like to eliminate)?
Other suggestions for the noise?
JamesC
Old Jan 25, 2013 | 06:31 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Shifter Lever Damper
The one in the offset shifter lever/block inside the transmission? Shifts don't fully go into gear and can pop out. It's not going to be a NVH issue until it's steel on steel and by then, you'd know the cup was worn.
They're way cheap and can be adhered in place to prevent shearing (if they rise out of the lever; this is a bigger problem on the 4-gates-wide T56 than it is on the 3-gates T5)
Old Jan 28, 2013 | 09:23 PM
Jeremy_worden's Avatar
Car: 1991 camaro RS
Engine: 3.1 v6 LHO
Transmission: 5 speed
Axle/Gears: 3.26
where could a guy go to get the damper sleeve?
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
