I need help with drum to disk swap.
Old Jan 27, 2013 | 04:07 AM
lethaldomestics's Avatar
i have a 1987 Firbird 305 TPI 700r4 Drum disk rear end.
i want to swap in a 1985 z28 3.43 gear rear disk break set up i found online (CL). i have searched around a bit and i couldn't find much. i was wondering what i have to do to get the breaks working properly. will it pretty much all bolt up? i do know i have to go get the good set of calipers i saw at the junk yard. should i grab anything else?
i m sure i can snag the parts for the job
Also are there any variation of caliper type?
Old Jan 27, 2013 | 05:11 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: I need help with drum to disk swap.
Go to the Brake Board and sart reading, all the info you need is there, first off determine if that rearend is a 9 or 10 bolt......
Old Jan 27, 2013 | 06:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
i want to swap in a 1985 z28 3.43 gear rear disk break set up....
There is no 3.43. A 10-bolt is 3.42, a 9-bolt 3.45.
Check the 10-bolt FAQ sticky above for info on master cylinders, combination valves, parking brake cables, caliper types an so on.
Since the swap is common a search should provide a wealth of information. Good luck with your project.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
92projectcamaro
Dec 8, 2015 12:25 AM
usafirebird
Sep 29, 2015 11:58 PM
dbrochard
Sep 25, 2015 04:56 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
