HOW DO I GET THE BEARING CONES OFF OF A 10 BOLT GM CARRIER / PINION ?
Old Jan 31, 2013 | 09:45 PM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
THERE IS VERY LITTLE ROOM TO GET A BEARING SPLITTER IN BETWEEN THE CARRIER AND BEARING CONE TO CHANGE IT OUT. IS THERE A TRICK TO THIS ? OR JUST A PAIR OF BIG PRY BARS ?
Old Jan 31, 2013 | 10:21 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: HOW DO I GET THE BEARING CONES OFF OF A 10 BOLT GM CARRIER / PINION ?
Bring your keyboard and your carrier over here; I'm off the 101.
I'll fix your dumbass caps lock you claim has been stuck for years and get the bearings off for you.
Old Jan 31, 2013 | 10:44 PM
DRIVE2FAST's Avatar
I CANT MY S-10 CMFI IS DOWN. @#$@#$ I HAVE A PRESS. WILL A REG BEARING SPLITTER WORK ?
Old Feb 1, 2013 | 07:14 AM
big gear head's Avatar
If you don't have the correct bearing puller then cut the cage off of the bearing. Then use a MIG welder and run a hot bead around the inner bearing race. The heat from the welder will loosen the bearing and you can pry it off with a pair of pry bars. Protect the gear and other parts from weld splatter. This is just one option. There are several ways to get them off.
Old Feb 1, 2013 | 07:35 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i paid $15.oo at a machine shop to have them take the old pinion bearing off, and press the new bearing on. he used a torch to cut the bearing. i dont have a press, so it was worth it to me.
Old Feb 1, 2013 | 08:02 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Get a piece of wood and tap the caps off (both KB and carrier).
Old Feb 1, 2013 | 09:38 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Cut the cage off with good cutters and use a cutoff wheel at a angle on 2 sides of the bearing race and it will crack and fall right off.
make sure you cover the carrier so junk doesn't get into it.
Old Feb 1, 2013 | 11:41 AM
DRIVE2FAST's Avatar
THAT SOUNDS LIKE IT WILL WORK. A DECENT BEARING SPLITTER KIT IS $500 OUCH.
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
