Torque Converters failure
Old Jan 31, 2013 | 10:54 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Axle/Gears: 9 inch 3.25/4.11,axles moser 31 spl
Torque Converters new broke counterweight
torque converter hugges gm25
Old Jan 31, 2013 | 11:27 PM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
Re: Torque Converters failure
I HAD ONE DO THAT . IT SHOOK THE PUMP TO DEATH. DESTROYED 700R4. HAD TO REBUILD EVERYTHING.
Attached Thumbnails Torque Converters failure-picture-019.jpg   Torque Converters failure-picture-017.jpg
Old Feb 1, 2013 | 09:24 AM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
which is the company of your torque converter
Old Feb 1, 2013 | 11:35 AM
DRIVE2FAST's Avatar
IT WAS A STOCK TORQUE CONVERTER THAT CAME FROM THE FACTORY. THE OWNER OF THE CAR BEFORE ME HAD ABANDONED THE CAR IN A PARKING LOT WITH A FAILED TRANSMISSION AND REAR END.
Old Feb 1, 2013 | 03:21 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
my huges torque converter was only 3 months and 1 km of travel
Old Feb 1, 2013 | 10:56 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
You should definitely call them. Hughes is a top rated company here on the forum. I would be very surprised if they didn't help you out. I'm not an expert on torque converters, but that looks like a bad weld. Even the best companies miss once in a while.
Old Feb 2, 2013 | 04:51 PM
DRIVE2FAST's Avatar
IT LOOKS LIKE THE T/C COLLIDED WITH SOMETHING....SPEED BUMP??
Old Feb 8, 2013 | 09:38 AM
Camarobreaker's Avatar
Car: 1989 IROC-Z
Lol What?? If there is a speedbump that can manage to get past your oil pan, tranny pan, and main engine cradle, then manage to hit the torque converter in the EXACT same spot as the weight, thats soooome speedbump.
gta892000
Aug 11, 2019 11:16 AM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
