trans fluid
Old Feb 3, 2013 | 05:17 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
trans fluid
FYI- I saw one of the car shows and they had a report on transmission fluid. There graph showed that it is designed to work in the 175-225 degree range. The additives are designed to work best in that range. At 250 the additives start to cook, at 275 the seals and rubber parts start to cook and at 300 you get trans failure because the clutches cook. They stated that the synthetic trans fluid should be used since it is much better and your trans will last a lot longer. I am going to install a trans temp gauge now and try and keep it in the 175 range. Anyone know of a good 2 1/16 gauge that works properly?
Old Feb 3, 2013 | 05:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: trans fluid
http://www.summitracing.com/search/d...rature%20gauge
maroe624
Apr 16, 2017 08:29 AM
LittleFranks
Sep 17, 2015 12:22 PM
spaigo
Aug 21, 2015 07:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
