NEED DRIVE TRAIN HELP!
Old Feb 8, 2013 | 03:35 PM
cel19's Avatar
Car: 1987 Camaro S.C
Engine: 355 ci
Hey all...I have a series 3 eaton posi and 3.73 gears. I love them and would like to keep them.....now I have a 350 stock and a 700r4 from an 89 camaro with eaton posi 3.73...it cooks on the highway at like 4.000rpm at like 80 mph. Is there anything I can do to help this??
I have 26 or 28 inch tall tires on rear
Anyone know if they make custom overdrive gears?? To like maybe .50 or something?
It also says the carrier 3 series fits 3.23 gears and higher. Does that mean I couldn't revert to the old 2.73 gears.
I need some serious input/Advice fellas
Old Feb 8, 2013 | 04:07 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: NEED DRIVE TRAIN HELP!
2:73 2-series gear set with the 3-series carrier witll not work. Enjoy your 3:73 gears @ 4000 rpms on the highway, just turn the radio volume up.
Old Feb 8, 2013 | 04:29 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Yea t56 swap an that will make ur rpm's drop big time at highway speeds
Old Feb 8, 2013 | 04:37 PM
cel19's Avatar
Engine: 355 ci
So dang....there's nothing I can do. So any 2 whatever gears would work for a series 2 diff. And any 3 whatever gears will work for a series 3 diff? Can I just drop down to like a 3.02 or 3.23 gears...
A t56? That's a 6-spd manual correct? If I had to go that route which I wouldn't but as a last resort could I use a 5-spd manual
Old Feb 8, 2013 | 05:37 PM
big gear head's Avatar
You can go to a 3.23 gear, but no more than that. Is overdrive working in that transmission? That seem like a lot of RPMs for that combination. RPMs at 80 with a 3.73, 26 inch tire and overdrive transmission should be around 2700.
http://www.ringpinion.com/Calculators/Calc_RPM.aspx
Old Feb 8, 2013 | 06:58 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Well, either what you posted is wrong or you have an incorrect tach reading.
70mph with a 26" tire is overall trans * rear ratio * 1000
So .70 (4th gear in 700-R4) * 3.73 * 1000 = 2611. That's a long way from 4000.
But maybe you have a V6 tach.
That's my best guess.
Old Feb 9, 2013 | 08:47 AM
cel19's Avatar
Engine: 355 ci
Hmmm well the car did come with a 2.8 mfi..
So I'm assuming the tach is still the same..
Old Feb 9, 2013 | 08:51 AM
cel19's Avatar
Engine: 355 ci
Well as for overdrive. Last night I had it in first and it went through all 4 gears. Shifted at about 3,000 to 3,500 rpm when it kicked into overdrive it went from 3500 to 3000 and immediately started climbing and screaming..it starts doing that high climb at about 55 - 60. .
Old Feb 9, 2013 | 08:55 AM
Hook up an after market tach and see what your RPMs actually are. You might have a transmission problem.
Old Feb 9, 2013 | 09:00 AM
cel19's Avatar
Engine: 355 ci
Hmm alrighty. Ill check and hook all that up and get back to you
Old Feb 9, 2013 | 10:35 AM
Right: if you have the 6-cyl tach and it's hooked up to a V8, then it's ALREADY reading 1.3333 times (8 ÷ 6) what it should; couple that with the tendency of these tachs to fail by reading high, and your "4000 RPM" will probably turn out to be quite a bit over-enthusiastic, like, it's REALLY about 25 - 2600 RPM.
Old Feb 9, 2013 | 11:11 AM
jmd's Avatar
jmd
Yep, that's it.
Buy a V8 tach. I don't think the Camaro ones are switchable 6 to 8 (some other OEM tachs are switchable.)
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
