9-bolt bent axle??
Old Feb 16, 2013 | 04:52 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
9-bolt bent axle??
I got the carrier in and all set up right and the axles in. I test fitted a disk on one side and measured the run out at the outside edge with a dial gauge. 0.003 inches. Is that acceptable? The 1Le caliper is centered and parallel to within a few thou' as well.
When I tried the same disk on the other axle the run out was 0.110 inches. I'm not a mechanic but that seems like it's too much. Am I correct and the only likely reason is the axle is bent? If so can the axle be straightened or is it better to get a new one or at least a straight used one? If the latter does anyone have a straight PS axle for sale?
Old Feb 16, 2013 | 05:05 PM
Re: 9-bolt bent axle??
Yeah that's too much.
That'll have the tire tread wobbling by around 5 times that amount; a half-inch or so. Clearly .... unpleasant at speed.
Yes most likely it's because the axle is bent. Surprisingly common actually.
Old Feb 16, 2013 | 07:07 PM
big gear head's Avatar
The .003 runout is all right, but .110 is way to omuch. That's going to cause a lot of problems with your brakes too. Check the runout on the axle flange without the disc and see what it is.
Old Feb 16, 2013 | 07:19 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I did and it was appreciable too compared to the good one. Got to bite the bullet and buy another.
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 7, 2015 09:41 AM
