nv4500 in a thrid gen?
Old Mar 1, 2013 | 04:54 AM
wgpengineering's Avatar
Car: 1984 Camaro
Engine: 305 HO/ soon to be 4.8L LR4
Transmission: 700R4/ soon to be NV4500
Axle/Gears: Ford 8.8 w/ 3.73 posi
has anyone ever managed to drop a nv4500/lsx combo into a third-gen? I managed to get one for practically nothing that is in good shape and wanted to know the pros/cons of using it...
an obvious pro AND con is the 1st gear ratio, which is well over 5:1 and coupled with 3.73s would make first gear short and useless... and make second gear similar to 700r4s first gear...
another question I have is where could one get a good clutch for said transmission/engine combo?
Posted from Thirdgen.org App for Android
Old Mar 1, 2013 | 11:31 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: nv4500 in a thrid gen?
I can't speak for an NV4500 but I can tell you the weaker NV3500 is pretty comparable in size to a 4L60E/700R4.
Old Mar 2, 2013 | 05:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You end up with a wide ratio slow shifting 3 spd with O/d and underdrive
1st gear good if you want to use your car for tractor pulling or rock climbing
Have you considered here the shifter would be?
Old Mar 2, 2013 | 10:39 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Same problems as a NV3500 swap, but with the further problem of adding another 100 pounds of iron case. Selling the 4500 would get you halfway to a T56.
Old Mar 6, 2013 | 05:14 AM
Car: 1984 Camaro
My problem with all this is the car is in NY, while i'm stationed in CA so i cant do all the mock up stuff on my free time...i'm not sure where the shifter would sit as i havent even seen the tranny at all haha a T56 would be awesome...what's a good price for one?
Where can i get a clutch for this tranny anyways? My cousin might be able to use it in his truck if i were to sell it but he would need a clutch...
Old Mar 6, 2013 | 05:34 AM
Twin_Turbo's Avatar
nv4500 is a top loader, the stick would end up in your ash tray or thereabouts. ?Kinda sucky, I had been looking for a 2wd nv4500 for my truck and couldn't find a decently priced one. They are perfect for trucks with floor shifters but completely useless for anything else
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
