9-bolt gear oil?
Old Mar 17, 2013 | 11:21 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
9-bolt gear oil?
I'm finishing up a 9-bolt rebuild and have a question about the oil. I've read several threads with different ideas about the weight and if additive is needed or not. I've never done this before and I got CRC Sta-Lube 80W90 GL-5 Plus for Hypoid Limited-Slip. It was the only one of that weight they had. Is this OK?
Old Mar 20, 2013 | 03:14 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: 9-bolt gear oil?
Don't think you need the posi additive for a 9 bolt. I believe it actually reduces friction on clutch type posi units to extend life.
Please correct me if I'm wrong.
Old Mar 20, 2013 | 05:31 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Yes the additive lets the clutches slip a bit going around turns. In 9 bolts most times you do not need the additive. I needed to add some to mine after i rebuilt it since it was so tight with the new cones that it would chirp tires going around tight corners. Now its good with the additive and still roasts both rear tires no problem.
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
