700r4 to t-5 swap
Old Mar 18, 2013 | 10:51 PM
asm383's Avatar
Car: 91 z28 convertible
Engine: 350lt1
700r4 to t-5 swap
What do I need for this conversion to be done?
Old Mar 19, 2013 | 07:24 PM
Re: 700r4 to t-5 swap
An intact V8 T-5 car that you won't mind throwing in the trash when you're done
Old Mar 20, 2013 | 09:42 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
also I'm doing a write up and nearly finished with mine. There are a lot of write ups out there if you search it.
Old Mar 29, 2013 | 04:40 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
TIRED OF 700R4 ?
Old Sep 6, 2013 | 03:42 PM
C. Hartwell's Avatar
I have recently decided to do a conversion on my '88 Camaro 2.8L . However, I am unsure where to start or what I will need. Is there a guide somewhere ???
Old Sep 18, 2013 | 06:07 AM
DRIVE2FAST's Avatar
ALOT OF WORK TO THROW AT A 2.8. SWITCH TO NEWER 3.1 V6 . I TEST DROVE ONE. MUCH BETTER ENG.
camaro11j
Sep 19, 2018 08:49 AM
midge54
Sep 2, 2015 06:27 PM
C409
Sep 1, 2015 03:42 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
