Moser 9" axle flange issues
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Notice the axle flange bolts? They aren't fully threaded. They are 4 T-shaped bolts, through the axle flange, into the brake mounting plate, with a lock washer before the nut. I'm a bit concerned with the nut only threaded that much. They are torqued to 45 ft-lbs, just to see if it would draw them in any more, but no luck. Any suggestions?
Also, anyone know the torque specs on these 4 bolts?
Engine: 385
Re: Moser 9" axle flange issues
Just the flange on the housing and the backing plate. Do these actually have lock washers on them? I assumed they went on there since I have 8 of them. What if I were to take off the lock washers and just use loctite on the nuts?
I never had a problem with them being long enough. Contact Moser and see what they say. They might have sent the wrong T bolts. They are pretty good about sending replacement parts if something is wrong.
Engine: 385
I'm planning on calling them tonight, but these are what came on it from the previous owner. He ran it roughly 2k miles. I didn't look real close at them when I took them off unfortunately.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
