Where to get 2 Terminal N.O. 4th Gear Pressure Switch
Old Mar 29, 2013 | 10:40 AM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
I have determined my switch In my 1985 700R4 to be normally closed and need a normaly open one instead. The issue I'm having is I can't find an N.O. one with 2 prongs like mine.
I'm not sure if this is the right part...
http://www.transmissionpartsusa.com/...-000047382.htm
Or
http://www.gmpartsdirect.com/results.cfm
This is with searching a part # of 8643710
Are these right? Can I just modify the wiring to use a one terminal switch?
(P.S. visited my local transmission place and they proved to be very unhelpful in getting me one so this seems to be the only practical way)
Old Mar 30, 2013 | 07:49 PM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Re: Where to get 2 Terminal N.O. 4th Gear Pressure Switch
Bump
Old Mar 31, 2013 | 05:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Assuming your are working on the TCC ???
You would need a 2 wire lock up solenoid (late style) with the power run through the solenoid then grounded by the 1 wire switch
as opposed to your current setup with the power going to ground through the self grounding solenoid after going through the switch
89GTAOz
May 16, 2020 09:31 AM
jklein337
Sep 19, 2018 06:23 PM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
dhonda200
Aug 11, 2015 11:50 PM
