Speedo Drive & Driven Gears
Anyone know where a color chart is for the drive & driven gears for GM?
I'm needing a 13 tooth drive gear & 26 tooth driven gear for a 2004r so it can correct my speedo and cause the ECM to make it shift correctly within the power band of the engine. Or will this not work? And the eprom has to be flashed?
1990 Caprice: 305 w/ 2004r
Replacement Rear end is a 3.42 gear GU6
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Speedo Drive & Driven Gears
you can find them on ebay or you can search the web they are out there
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might take notice that TGO is dedicated to 82-92 F-bodies.
JamesC
Car: check
Engine: check
Transmission: check
RBob.
Seriously,
Just because the factory didn't mix and match. Doesn't mean it will not work or that it is not the same. All of it will interchange. Thus being all the same ****. Why do people like you even bother to open your trap? Thank you for wasting my time.
Axle/Gears: '01 3.42 10 bolt
not wasting your time. you would find more information on a b-body forum or an s10 forum since that is what you are putting it into.
beachrodder
Aug 7, 2015 04:27 PM
