Identify this diff?
Old Apr 7, 2013 | 09:47 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Identify this diff?
Have another diff for you guys to check out. Just picked this up from a TGO member this morning.
Let me know what you guys think..
Old Apr 7, 2013 | 11:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Identify this diff?
It's a 10 bolt with an Eaton posi inside.
Old Apr 8, 2013 | 06:16 AM
A 2 series one, with a "thick" ring gear.
Old Apr 8, 2013 | 06:40 AM
Engine: 450HP 355
Transmission: TH350
So is it safe to assume that this will hold up to my V6 better than the previously killed Auburn at the strip?
Old Apr 8, 2013 | 06:59 AM
big gear head's Avatar
That is NOT an Eaton Posi. That is a cone type differential, probably an Auburn.
Old Apr 8, 2013 | 08:55 PM
Engine: 450HP 355
Transmission: TH350
^^ Looks like you're right, it's an Auburn. I found a pic on Jegs that confirms it..
Now to contact them and see what the stampings show it is..
Old Apr 9, 2013 | 05:39 AM
Yup, it's an Auburn; a stock one, at that. 2 series. Pretty much, the dung.
What difference does it make "what it is"? That is, what would you do with that info, if you had it? I can tell you Auburn is among the least helpful companies there is, when it comes to maintaining their existing customer product base; more than likely they won't tell you anything you don't already know. Maybe there's some other way of finding out what you need to know?
Old Apr 9, 2013 | 06:59 AM
What is the gear ratio?
Old Apr 9, 2013 | 02:06 PM
Engine: 450HP 355
Transmission: TH350
4.10
sofakingdom, I had noticed that they have some 30 spline units and a few others on Jegs. I was hoping just to get total confirmation from them on the diff specs. 26 vs 28 spline, etc...
The numbers I have are partially covered up by the ring gear, the lady from Auburn was nice but said that i needed the rest of the numbers for her to help.
Old Apr 9, 2013 | 03:45 PM
I would say that it's a 3 series if the gear is a 4.10. It doesn't look all that thick for a 4.10 gear. You can remove an axle very easily and see what the splins are.
Old Apr 9, 2013 | 05:19 PM
30 splines would be for some other model of rear end... this model (7.5" / 7.625") only comes in 26 or 28 splines on the axles.
Old Apr 9, 2013 | 09:33 PM
Engine: 450HP 355
Transmission: TH350
^ that makes sense.
I was hoping not to have to take it apart but i'm waiting on a new diff cover and LCA brackets so i do have some time. The axles in my broken rear are 26 spline and in good shape, would be nice to have a spare set.
Thanks guys, it'll be nice to drive my car again at least. lol
Old Apr 10, 2013 | 06:43 AM
2 series vs 3 series...
Note how the 2 series ring gear flange is essentially flat on the side opposite the gear (because the flange is so close to the bearing), but the 3 series is more cone-shaped (to locate the flange closer to the center of the pinion).
Yours looks 2 series.
Old Apr 10, 2013 | 07:22 AM
You are going to have to see a picture of the left side of the differential before you can tell if it's a 2 or 3 series. The picture doesn't show that side well enough to tell the difference.
Old Apr 10, 2013 | 11:42 AM
Engine: 450HP 355
Transmission: TH350
Here is a pic from a little better angle..
Old Apr 10, 2013 | 11:54 AM
Still looks like a 3 series to me.
Old Apr 10, 2013 | 12:14 PM
Engine: 450HP 355
Transmission: TH350
crossing the part number on the ring gear shows it's for a 3 series.
Either way, still better than the old diff.
Numbah-1
Oct 2, 2015 08:27 AM
Vincent135
Sep 28, 2015 10:50 PM
