B&M Mega Shifter Relay #275-206
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Does anyone have a picture of how the relay is mounted inside of their center console with the B&M Mega Shifter?
I want to solder in the wires but I dont know where to mount the relay since it does not come with a base/connector. Here is the relay below....
http://i1234.photobucket.com/albums/...ps55095908.jpg
http://i1234.photobucket.com/albums/...ps47bb4af0.jpg
http://i1234.photobucket.com/albums/...ps2b09492d.jpg
I want to solder in the wires but I dont know where to mount the relay since it does not come with a base/connector. Here is the relay below....http://i1234.photobucket.com/albums/...ps55095908.jpg
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: B&M Mega Shifter Relay #275-206
Looks a pretty generic industrial style relay ; prob Radio Shack would have the base for it
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Page 4 has the relay diagram.
http://bmracing.com/wp-bnmcont/uploads/80692.pdf
Engine: Lb9
Transmission: M20
Use some Velcro to mount the relay in the console
Engine: Lb9
Transmission: M20
I'm sure you can figure out a place to zip tie it to than, the wires come from under the dash so the relay can be relocated and does not need to be in the center console.
Car: 82 Z28
Transmission: T400
I had no problems running my starter wiring through the B&M micro switch
and had no problems with the P/N indication (org / blk wire ) to the ECM being disconnected.
It only changes the idle revs by 50-100 RPM ? (TP will know how much) anyway and if you have a non stock setup with a cam most likely you will have a higher idle programmed anyway
