Leaking bolts at the front oil pump
Old Apr 24, 2013 | 03:52 PM
kissedin's Avatar
Car: Trans Am
Transmission: TH350
I' driving a 82 trans am (305 v8) with the th350 trans.
I noticed a leak from the front pump. But before I go to a mecanic there is one thing I'd like to try... As I have understood there is supposed to be a washer at each of the bolts at the front pump. But there are none as far as I can see on my trans.
Questions:
1. what kind of washers do I need? copper?
2. I think i can get out the bolt that is leaking and put a washer on it without dropping the trans. But what will happen if I just unscrew one of these bolts? I there a risk i will mess something up?
3. in case I can't get the bolt out is it any idea to try with RTV-sealant? (unscrew the bolt and apply a coat of rtv under the bolt head.)
Dropping the trans is not an option for me. If that is necessary i will go to a mechanic - so adding these washers is my last try (and hope).
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Exxon Limited
Aug 9, 2015 08:13 PM
