ID gears and Diff question.
Old Apr 26, 2013 | 03:04 PM
hjsmith00843's Avatar
Have a leaking pinion seal and decided to pull the cover. The oil looked brand new just a little low. I know it is a peg leg pull but can you tell me what gears these are. Also I have the chance to get the rear diff out of a 1995 Camaro. Will it fit with no problems. It is the 10 bolt and has drum brakes.
I assume it has posi. Will pull the cover to confirm this.
What should I look for when I pull the cover to see what it is. I will post pictures when I inspect it. What gear would a stock 1995 camaro have that comes with drum brakes. I would think it was the 3.1 engine model.
Here are the pictures. (the pictures are of my current rear end and not the 1995 rear diff)
Old Apr 26, 2013 | 03:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ID gears and Diff question.
Originally Posted by hjsmith00843
...can you tell me what gears these are.
13/42= 3.23's. The following may be useful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 26, 2013 | 04:03 PM
big gear head's Avatar
Yea, it's a 3.23 gear. A '95 rear end from a V6 car is probably going to have a standard differential. It will also have 28 spline axles, so if yours is a '89 or older your axles are going to be 26 spline and you can not use the differential anyway.
carattini
Sep 10, 2015 07:46 AM
toyotekk
Sep 6, 2015 02:21 PM
Ian Irvine
Sep 4, 2015 08:08 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
