Gears
Old May 1, 2013 | 11:08 AM
1992PonFirebird's Avatar
Car: 1992 Pontiac Firebird
Engine: 400 sbc
Axle/Gears: 3.73 Limited-Slip
Gears
I have a 92 Pontiac Firebird with a 305 tbi and a 700r4 transmission but I don't know what the gears are. Does anyone know what those came with and if it was a 26 spline or 28 spline? I have a new Richmond 3.73 gears for a 7.5in 10 bolt Chevy rear end and a new posi differential for a 28 spline and I just want to make sure they are going to work before I start taking things apart and I'm out of a car for a couple of days.
Old May 1, 2013 | 11:32 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Gears
I'm not tryn to be a azz but i'm going to say, that if you can't figure out what gears you have in your car now, maaaybe you shouldn't be swaping gears in your own car.
Old May 1, 2013 | 11:39 AM
Engine: 400 sbc
Re: Gears
Well maybe you shouldn't worry about that. I didn't say anything about installing. I just want to know the gears so if you have nothing good to say just keep it to yourself
Old May 1, 2013 | 11:50 AM
TTOP350's Avatar
Re: Gears
Old May 1, 2013 | 12:10 PM
big gear head's Avatar
Re: Gears
https://www.thirdgen.org/forums/tran...-10-bolts.html
Everything you need to know is right here.
Old May 1, 2013 | 07:47 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Gears
Heres a link to check out = https://www.thirdgen.org/1992-pontiac-firebird
Old May 4, 2013 | 12:05 AM
Engine: 400 sbc
Re: Gears
Thank you. I got the gears and differential changed out. Yes TTOP350 I did it myself and it runs great.
Old May 4, 2013 | 03:07 AM
TTOP350's Avatar
Re: Gears
Thats good to hear, I'll sleep better knowing that.
How did you correct the speedometer?
Old May 4, 2013 | 01:43 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Gears
305 TBI auto more than likely has 2.73
Old May 6, 2013 | 08:59 AM
Engine: 400 sbc
Re: Gears
I pulled off the extension housing on the transmission and pulled the old speedometer gears out and my brother did a calculation to figure out which speedometer gears I needed for my rims and tires and the new gears and just got one from his work and installed it. Yes they were the 2.73
Old May 6, 2013 | 03:12 PM
Engine: TBI,5.0
Re: Gears
If you went from a open 2.73 differential to a 3.73 posi. than you must be happy as far as the difference goes. I went from a 2.73 to a 3.42 with a Eaton posi. and L.P.W. Support cover and it was like night and day. Congratulations. One of the other things I did was put a Corvette servo into the 700r4 and it really tightened up the shifts.
http://www.sethirdgen.org/servo.htm
Old May 6, 2013 | 03:16 PM
Engine: 400 sbc
Re: Gears
I love the difference. The gas milage went down a ton but hey I don't drive a muscle car for the fuel economy
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
