4th gen rear wheel studs
Old May 3, 2013 | 01:35 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Hey fellas,
i've got a problem. I broke a wheel stud on my 4th gen rear which happens to have a traction control or abs ring on it. I can't get the wheel studs to clear. I know that you have to remove the axle and have it pressed off then back on but since I have a 3rd gen I really don't need it. My question is can I air chisel it off and save some time and money or does it need to be there?
Old May 3, 2013 | 02:17 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 4th gen rear wheel studs
A local shop[ replaced 2 of my wheels studs on my 9-bolt on one axle by using air tools to drive the bad stud out then an air impact to pull the new stud in. Just need to see if there is any room between the wheel flange (axle end) & the backing place for the stud to clear going out or the new one coming in.
Old May 3, 2013 | 02:19 PM
jas2730's Avatar
There is no room which is the whole reason for me posting.
Old May 3, 2013 | 02:22 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I've pushed a broken wheel lug out with a center punch and mallet and pulled one back in with a 4 way and using an over-sized lugnut as a spacer. This was on non-abs brakes but I don't see why it wouldn't work as long as you have clearance between the flange and the backing plate.
Old May 3, 2013 | 02:25 PM
jas2730's Avatar
Are you guys reading before you post? I clearly stated that the studs WILL NOT CLEAR!
Old May 3, 2013 | 02:28 PM
Richboll's Avatar
Engine: 305 TBI
Sorry..usually when you get the splined part out you have lots of wiggle room to get the rest of the stud out. I don't have a 4th gen so i'm not familiar with the. But Hey, I guess you'll need to pull the axle.
Old May 3, 2013 | 02:41 PM
Car: GTA
Yes....We can read, but if you are going to insult people then nobody will help you.
You can cut the stud you want to get out & until you actusally TRY to put the new one in, you will not KNOW that it can't be put in. You'd be surprised at what a little extra effort will get you.
Or drill a hole in the brake backing plate for the stud to go through to reach the axle flange. The axle ends are very similar so I seriously doubt that a new stud cannot be put in without pulling the axle.
Worst case? Pull the diff cover, pull out the c-clip retainer & pull the axle. It isn't that hard to do. Sometimes trying short cuts cost you more than you thought you were gonna save.
I duuno about the ABS ring, but if you don't need it & removing it isn't gonna harm the axle then cut it off.
Old May 3, 2013 | 02:46 PM
jas2730's Avatar
First things first, where do you find an insult any where in my posts? Second, I'm talking about cutting the abs or traction ring off itself. Not the studs or the backing plate. I didn't say you couldn't read. I asked if you were reading.
Old May 3, 2013 | 02:49 PM
jas2730's Avatar
I'm a little wired and patience is in short supply today. Apologies.
Old May 3, 2013 | 02:53 PM
Car: GTA
Post #5....Suggesting we are posting without reading first is insulting.
But...I'm done.
Are you reading before posting? I already told you.....
Drill a hole.
Cut the ring.
Or stop looking for take a short cut & do it correctly by pulling the axle.
Those are your only 3 options. Choose one.
Old May 3, 2013 | 02:56 PM
jas2730's Avatar
Thank you buddy.
Old May 3, 2013 | 05:37 PM
Pop the axle out; use a bearing splitter on the tone ring. Don't even need a press, you can just use a hammer.
Piece o cake.
Old May 3, 2013 | 06:29 PM
jas2730's Avatar
Pop the axle out; use a bearing splitter on the tone ring. Don't even need a press, you can just use a hammer. Piece o cake.
Pulled the axles, removed them with a pry bar. Going to put in my Detroit locker and Richmond 4.10 gears since it's all apart anyway and reassemble tomorrow.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
