spider gears
Old May 15, 2013 | 06:37 PM
Psudokiller's Avatar
Car: 1992 camaro rs
Engine: 3.1l v6
Transmission: t5 5speed
Axle/Gears: 7.75" 9 bolt, 4.11posi, disc brakes
spider gears
i have a 1992 camaro with a 7.625" 10 bolt axle with 28 spline shafts and an open diff.
additionally i have a gm 7.5" 10 bolt with a posi and 26 spline shafts.
now the question, i know the carriers will swap and i know the shafts will swap, BUT can i take the spider and side gears from the open carrier (28 spline) and put them into the posi carrier (26 spline) so that i can utilize the 28 spline shafts in the posi carrier, or will i need to buy a new posi unit.
thank you.
Old May 15, 2013 | 06:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: spider gears
I doubt the spiders are the same between an open and posi diff but they may be. Although normal 28 spline spiders will fit into a 26 spline carrier, the hole that the axle goes through in the case isn't large enough for the 28 spline axles.
Old May 15, 2013 | 09:16 PM
Car: 1992 camaro rs
Engine: 3.1l v6
Re: spider gears
if you mean the axle housing i am using the housing currently in my camaro that already has the 28 spline shafts, if you mean the differantial carrier im not sure but the 26spline shafts did have some wiggle room when installed in the other housing (not sure how much just an eyeball guess)
i plan on atempting the swap this weekend (i will remove one shaft and test before i remove the carrier) as i already plan on swaping the disc brake setup from the iroc axle onto mine.
Old May 15, 2013 | 09:24 PM
big gear head's Avatar
Re: spider gears
No it won't work. You will have to get a 28 spline posi. I recommend the Eaton Posi or Yukon Dura Grip.
Old May 15, 2013 | 09:49 PM
Car: 1992 camaro rs
Engine: 3.1l v6
Re: spider gears
well since i cant afford one, i am going to have to run the open, thanks
Old May 16, 2013 | 06:51 AM
Re: spider gears
Check ebay for a used Torsen from a 4th gen. Be sure to get the correct series for the gear that you have.
Old May 17, 2013 | 07:04 PM
Car: 1992 camaro rs
Engine: 3.1l v6
Re: spider gears
that would work if i diddent have $68 to my name, they dont pay us very much in the reserves and i am still looking for a job, but thank you
Old May 18, 2013 | 06:26 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: spider gears
I once tried pushing the 28-spline shafts into a 26-spline carrier; no go. I would have had to get the carrier machined. Not worth it in that instance.
Old Jun 5, 2013 | 06:58 AM
Car: 1992 camaro rs
Engine: 3.1l v6
Re: spider gears
i was refering to taking the 28 spline spider gears themselves out of the open carrier and putting them into the posi carrier, not just the shafts, but thanks
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
