Shift Cable - Auto; Mod it?
Old Jan 8, 2014 | 10:39 AM
  #51
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Shift Cable - Auto; Mod it?
my autozone cable is getting looser and looser and i don't want to get another one.
I shift gears at the track in the burnout box from 1 to 2 to 3 then roll out of the water box. I can only get this autozone cable down to 2nd gear now, won't go into 1st.
I need this new cable like yesterday.
Any way we can take pre-orders to get the supplier to move faster?
Old Jan 16, 2014 | 09:35 PM
  #52
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Looks good!... hopefully will help from skipping 2nd and going into D.
Old Jan 17, 2014 | 10:52 AM
  #53
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Here is the latest news:
I have made drawings of new connectors for the bulk heads and sent to the manufacturer for a prototype. Now I just wait for them. These will be more expensive cables than what I sell now because the ends are different and I will also have to supply a new pin for the trans lever.
I dont know how much yet.
I know cost is always a factor, but a quality USA made cable is the goal. Keep you posted as I get more info.
Old Jan 17, 2014 | 11:04 AM
  #54
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Quality made USA cable that works accurately and won't break is what I'll buy.
Old Feb 28, 2014 | 03:46 AM
  #55
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Updates?
Old Feb 28, 2014 | 10:55 AM
  #56
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Slight hiccup in manufacturing, but it is addressed. Should have some pics of what the new bulkhead connectors look like, shortly.
Old Feb 28, 2014 | 12:00 PM
  #57
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
subscribed.
Old Mar 8, 2014 | 09:35 AM
  #58
Good stuff can't wait to see this!
Old Mar 19, 2014 | 12:44 PM
  #59
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
The prototype is finished. Here is the message sent:
Hi Brian
I finally have a new prototype.
It will require the use of a pin on the lever on the Trans. I believe you are currently using one that you ground down to fit. I have new ones drawn but not made because it remains to be seen the price of these cables.
I am going to get a second one made so if there are issues I still have a sample in hand.
Herb
Again, please don't contact Shiftworks till we have a production piece. Here are two pics of the prototype:
Old Mar 19, 2014 | 02:52 PM
  #60
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Looks solid! And that thing's not too stiff on the shiftplate for shifter movement?
Old Mar 19, 2014 | 04:18 PM
  #61
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Not at all. The end moves in and out of the sheath or tube. I helped him buy the shifter mechanism from this board. He knows what he's doing.
Next step is reduplicating the prototype within tolerances. Then we're good to go.
Old Mar 19, 2014 | 04:46 PM
  #62
Stoked... !
Old May 4, 2014 | 07:15 PM
  #63
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Should have some news, shortly.
Old May 4, 2014 | 08:14 PM
  #64
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
If this cable is adjustable then its a winner. I went through two cables at AutoZone w/ free replacement. Then I found the problem is not the cable. Look at this post #34
https://www.thirdgen.org/forums/tran...djustment.html
the problem is the trans lever. After adjusting I have not had any issues
Old May 8, 2014 | 10:34 PM
  #65
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Transmission: TH-700R4
Axle/Gears: 2.77
That didnt work on mine. New cable is 1\4 to 1\2 too short and old cable would work fine had the plastic had not broken. im still on board with the cable being created
Old May 8, 2014 | 10:48 PM
  #66
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
cable will not be adjustable. It will be stock replacement. Tracking number says it will arrive on Monday
Old May 12, 2014 | 09:59 PM
  #67
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Final prototype in my hands!
Landscape pic clipped the tip off, but it's the same on both ends.
Old May 12, 2014 | 10:01 PM
  #68
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Trans end bulkhead connector
Snugs up tight with the clip
Old May 12, 2014 | 10:03 PM
  #69
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
As you can see, the bulkhead connectors are custom made - AND DO ALLOW FOR SOME ADJUSTMENT ON THE THREADS!!!!
Old May 13, 2014 | 01:40 AM
  #70
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Looks awesome!
Old May 13, 2014 | 09:08 AM
  #71
zombi_360's Avatar
Car: 1989 IrocZ
Engine: 5.7 350
Axle/Gears: 2.77
looks promising! How long until it goes into production? I have this 89 IROC-Z that's been asleep since 2001. And where do we go to place an order?
Old May 13, 2014 | 01:33 PM
  #72
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
X2
Old May 29, 2014 | 09:28 PM
  #73
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Here's the final prototype in the car. Here you can see the new bulkhead connector fits without the "keeper."
No difference in drive-ability from before. Inspires confidence!
I'll let you know the final details as soon as I get them.
Old Jun 6, 2014 | 09:01 PM
  #74
buddybraga's Avatar
ok i need that cable tedsgrad where can i get one i need asap
Old Jun 6, 2014 | 11:10 PM
  #75
project89's Avatar
same here when will these be available
Old Jun 7, 2014 | 03:15 PM
  #76
buddybraga's Avatar
so has anyone tried useing a shifter cable that is similar like on of a 2nd gen gm
Old Jun 26, 2014 | 06:21 PM
  #77
JnC92Z28's Avatar
Car: 1992 Z28
Engine: 5.7L TPI
Transmission: A/T
Axle/Gears: G92 / 3.23
Is this cable available yet? Pricing? Looks awesome...
Old Jul 11, 2014 | 03:02 PM
  #78
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
This prototype thread is completed.
You can order the cables --> https://www.thirdgen.org/forums/tran...ml#post5790876
Old Aug 6, 2014 | 11:19 AM
  #79
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
What's the expected wait time to get a cable? Thanks.
Old Aug 31, 2023 | 11:41 PM
  #80
Rambo477's Avatar
Car: 1937 Chevy 2 Door Sedan
Engine: 5.7 out of 1996 Police Interceptor
Transmission: 4L60e out of the same donor
I tried searching threads and this was the closest to my issue. I’m working on a 1937 Chevy 2 door sedan street rod. It has the drive train out of a 1996 police interceptor Camaro. It was hard to shift into park with the steel transmission pan on it. I’ve put an aluminum finned trans pan on with the newer blue silicone gasket and now it won’t go into park unless you really slam it. With the bottom disconnected from the shifter ball at the trans, the cable seems about 3/8-1/2 inch too short with no way to adjust it. I measured the cable and center of eye to center of eye is 28 1/4 inches on the original cable. I’ve already got it pulled out of the vehicle. Thank you for your time, Derrick Bell
Old Sep 1, 2023 | 07:22 AM
  #81
Car: 1983 Z28
Sounds like you need to find a shop that makes custom cables. Get one a little bit longer than what you need and make sure it's adjustable.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
dhonda200
Aug 11, 2015 11:50 PM
