700R4 options
Old May 25, 2013 | 04:24 PM
L98Sonoma's Avatar
Car: 1993 GMC Sonoma
Engine: 5.7L TPI
700R4 options
I've got my engine working well but my 700R4 is just lacking the performance feel that should accompany the TPI engine. I'd like too tighten up the shift points and remove the slush box feeling when i press the gas. I want to be able too put in D and go, and OR bang it through the gears if i want too.
What Shift kit would be recommended that would help?
I've read that a Corvette Servo helps but i dont know what it does, if somobody wants too explain what it does.
Im also curious too know if there is a better Torque Converter too use with a Stock TPI engine.
FYI this setup is in a 93 Sonoma not a Third Gen.
Also, my transmission has a slight shudder under light throttle in first gear. Any guess if the transmission is damage or should i look at something else?
Thanks for the help
Josh
Old May 25, 2013 | 07:27 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: 700R4 options
tvmadeez from Bowtie Overdrive.
Tons of 700r4 information.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
david068513
Sep 18, 2015 10:36 AM
