drivetrain vibration
Old Jun 4, 2013 | 10:28 PM
TAG305's Avatar
Car: 87 firebird formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 373:1
ive got a 87 firebird vette rims 4th gen rear axle 3.73 gears stock drive shaft trans engine. trans is a t5 when i go around 75-100 mph i get a strong vribration faster i go the worse it gets. wondering if any has came across this problem only drive train no vibrations in steering wheel or front end shifter vibrates like crazy. i think drive shaft might be off balanced but trying to get more ideas.
thanks trevor
Old Jun 5, 2013 | 07:39 AM
big gear head's Avatar
Re: drivetrain vibration
Drive shaft is not out of ballance, it is bending at that speed. You need a stronger drive shaft. Going up 1/2 inch in diameter usually is enough to fix it, but increasing the wall thickness is also a good idea. Also going to aluminum will help because a lighter shaft will have less bending force on it at higher speeds.
Old Jun 5, 2013 | 11:10 AM
TAG305's Avatar
Engine: 305 tpi
Transmission: t5
Axle/Gears: 373:1
Will a 4th gen aluminum drive shaft fix it?
Old Jun 5, 2013 | 11:21 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
It should if it's balanced properly still. The aluminum shafts are much lighter than our factory steel and the LS1 type can have a dampening collar built in on the transmission yoke.
This is also a good place to note LS1 Aluminum driveshafts are notorious for breaking in stock M6 cars. Just something to keep in mind.
Old Jun 5, 2013 | 11:28 AM
TAG305's Avatar
Engine: 305 tpi
Transmission: t5
Axle/Gears: 373:1
I just got 305 tpi but will the 4th gen slide in and good to go to the t5 ?
And thanks for your help
Old Jun 5, 2013 | 11:46 AM
Engine: 383 SBC
Yes. The 4th gen factory v8 driveshafts should be a direct fit with an OEM Transmission.
Old Jun 5, 2013 | 12:12 PM
TAG305's Avatar
Engine: 305 tpi
Transmission: t5
Axle/Gears: 373:1
That's what I thought and was just making sure
Thanks for all the help guys almost sent in oem to get balanced
Old Jun 7, 2013 | 12:29 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Hmmm.. I have a alum d/s, just had it balanced and Im experiencing the same thing. Guess i should look into an aftermarket piece.. Damnit!!
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
