zz1 crate engine internal or external balanced flywheel?
Old Jun 13, 2013 | 09:16 PM
89stkformula's Avatar
Car: 1989 formula firebird
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
I tried looking this up with no real luck. Some people say it needs a external balanced flex plate / fly wheel and others say no. One form I read said the zzz owners manual recommends external balance. Any info would be helpful especially from other zzz zz1 zz2 zz3 owners. thanks
Old Jun 14, 2013 | 06:33 AM
Re: zz1 crate engine internal or external balanced flywheel?
If memory serves, that motor takes the same flex plate or flywheel as any other 1-pc rear main seal motor.
It is INTERNALLY balanced, with the rearmost bit of INTERNAL balance weight located on the flywheel rather than on the crank.
Old Jun 14, 2013 | 10:38 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
ZZ3 and ZZ4 are absolutely 86-up L98 / LT1 style flywheel compatible.
I'd assume based on production years the ZZZ is too.
If it's out of the car, look at the flywheel for a weight. 85-down 350 doesn't have one; 86-up does.
If it's in the car, do some decoding:
http://www.nastyz28.com/chevy-engine-code-stampings.php
http://www.nastyz28.com/sbchevy/sblock.php
Ah, this confirms it:
http://www.crateenginedepot.com/pdfs/sb_zzengine.pdf
Old Jun 14, 2013 | 07:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Externally WEIGHTED; not externally BALANCED.
Two completely different situations.
As the others have noted ; anything to suit a 1 pce RMS engine
Old Jun 14, 2013 | 08:05 PM
Twin_Turbo's Avatar
Which is weighted because a 1pc RMS engine is not 100% internally balanced (unlike a 2pc rear main anything but a 400)
Old Jun 14, 2013 | 09:22 PM
Yes those motors ARE 100% INTERNALLY balanced.
The rearmost bit of INTERNAL weight is located on the flywheel or flex plate. The fact that it is on an "externally mounted" piece DOES NOT alter the fact that the motor is INTERNALLY balanced.
The terms "internal" and "external" balance DO NOT refer to which side of the split between the crank and the flywheel the weight is on.
Old Jun 14, 2013 | 09:48 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
so my flywheel off my 305 will work?
Old Jun 14, 2013 | 10:19 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If it bolts to the crankshaft on the ZZ engine ,it is the correct one
Old Jun 14, 2013 | 10:28 PM
jmd's Avatar
jmd
89, yep.
If you've time talk a bit more about the engine. I had completely forgotten there was a zz1 and 2. You pick it up used?
Old Jun 14, 2013 | 11:17 PM
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
Originally Posted by jmd
89, yep.
Yea picked it used from a salvage yard in Florida but has some issues going to need a cam since it has some wear on a lope. I am also installing new rod bearings.
italiano67
Dec 11, 2016 09:21 AM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
cRoe4
Aug 7, 2015 08:46 PM
