ok guys i'm at my witts end here. I have a transmission leak coming from the bell housing area of my 700r4. I replaced the torque converter seal put it all back together and its still leaking. it only leaks when it's running the leak is coming off of he converter it's about 1/2inch and wide 14 to 16 long it goes from the center of the converter to the passenger side. could the o-ring at the pump be the problem? please help!!
antoine
close
I will guest front pump bushing
I'm dealing with a similar issue. I can't seem to get to the top bolts on the bell housing. How did you get to them in order to drop the transmission, so I can see what is going on.
Quote:
I pulled the distributor. That opened up all kinds of room.Originally Posted by killpatty
I'm dealing with a similar issue. I can't seem to get to the top bolts on the bell housing. How did you get to them in order to drop the transmission, so I can see what is going on. Quote:
Originally Posted by Icantthinkofone
ok guys i'm at my witts end here. I have a transmission leak coming from the bell housing area of my 700r4. I replaced the torque converter seal put it all back together and its still leaking. it only leaks when it's running the leak is coming off of he converter it's about 1/2inch and wide 14 to 16 long it goes from the center of the converter to the passenger side. could the o-ring at the pump be the problem? please help!! So I pulled the transmission out tore it apart replaced the pump bushing,o-ring,gasket and torque converter seal. I put it all back together just to find my leak still there!!! I then tore it all back apart only to find the weld from the snout to the converter body is very poor quality and that's where my leak was coming from all along.
