is the Hawks T56 conversion worth it?
Old Jun 30, 2013 | 06:47 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
So in my search for a better transmission I have been mainly looking at the 700r4, but I would really love a manual. Performance is my main purpose, but gas mileage is a huge plus and the T56 seems to be in both worlds ( hard to beat 1600 rpms with 3.73s in 6th). Hawks has the t56 conversion for our cars listed at $2,250+ shipping, and will need new internals like the slave and master. I might be able to find one at the junk yard for much cheaper, but will have to take everything out of the car for the swap.
At least with a manual I can install easier than auto, and my dad can help a bit as he did manual installs on his trucks back in the day.
I should have the one piece rear seal as the engine is from 2010. So shouldn't have a problem there.
So the main question is, is it worth it to pay around $2500 for the whole conversion, plus a little more for the rebuild parts?
Old Jul 1, 2013 | 01:19 AM
krazeefewl's Avatar
Car: 1991 Camaro RS
Engine: 305 will be LSX eventually
Axle/Gears: Borg Warner
Re: is the Hawks T56 conversion worth it?
I just checked out hawks site, and you won't need to purchase the slave and master as they come with it, but purchasing new ones is a good idea anyway. I have been looking to do the swap in my car for a while now and will say that you would be able to do it cheaper than what they list. Not to mention the cost of the shipping; I do wonder how much that would add to it? I would say that the price is reasonable, but if you're on a budget it can definitely be done for cheaper finding the parts you need locally. (If you have the time for that) If you need it all now that may be your way to go.
Old Jul 1, 2013 | 03:15 AM
Dabesiv's Avatar
Yeah, I figured I would just replace everything at once while its easily accessible if I got it. It's cheaper than anywhere else, but most everywhere else sells a rebuilt trans, not just a pulled one. Granted the cost to order everything separately would be terribly high too. I'm expecting shipping to be around $150-$300 which is average. A budget would be nice to keep too as this is already over $1000 more than it would be to do a 700R-4. I am gonna need to do some calling locally and see if anyone as it for dirt cheap because it would be a much nicer way to go. I hopefully have a few months to do this before the 200c gives out completely, it's already starting to have a hard time shifting gears properly which happened last time it took a dump. But we will see.
Old Jul 1, 2013 | 07:00 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
I think you should shop around, take your time. The price hawks sells it for is high and you will want new stuff too.
I was going to go that route but I realized I wanted a new clutch,flywheels,shifter,mast slave.
you can pick up a swap for under 2k, sometimes even 1k but If im putting somthing on my car I want to do it right and do it right once the fist time.
Old Jul 1, 2013 | 07:22 AM
Dabesiv's Avatar
My thoughts exactly. I may just do the 700R-4 for now and use some of the money saved in gas to get parts bit by bit for the T56. Maybe save up for a nice whole package of rear end and re built transmission. I expect it to be a long and interesting project to get everything how I need it and might as well take my time and learn everything about it on the way.
topteam54
Oct 6, 2015 12:21 AM
el_muerte
Sep 16, 2015 12:01 AM
mygta87
Sep 14, 2015 10:36 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
tonys91rs
Sep 2, 2015 07:07 PM
