stuck in 1st, cant put car in park help
Old Jul 4, 2013 | 12:18 AM
Sinfulrelations's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
hello everyone, im having one of the weirdest issues yet with my 92 camaro, today while i was driving i downshifted manually from overdrive to 1st, when i wen to put it back to overdrive it stayed in first and the shifter felt like i wasnt changing gears, when i got home and shut it off i couldnt put it in park, but yet i can still start the car when the indicator is on park or neutral, so now im stuck in first and im at a loss and am looking for advice... anyone have any ideas on what it could be???
Old Jul 4, 2013 | 12:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: stuck in 1st, cant put car in park help
Why ?
Because the P/N switch that locks out the starter is attached to the shifter ( that is still moving correctly ) ; not the trans
the shifter felt like i wasnt changing gears,... anyone have any ideas on what it could be???
Most likely you broke the cable , it's attachment or it's parts inside the trans that select the gears
Jack car , get under drv side , have someone move the shifter while you check out the trans end.If the cable is not moving may be
broken at shifter end .
If the cable moves and the shaft into the trans is moving ,then your problem is inside the trans.
Drop the pan
Old Jul 4, 2013 | 03:06 PM
draco1366's Avatar
i have done it, you broke the cable. not expensive and relatively easy to replace.
pop the cover that goes around the shifter (which probably has a name lol) and one end of the cable is there, push clip style
pass? side of trans, is the other end, also push clip style (at least it was on my 92 rs)
Old Jul 4, 2013 | 10:44 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by draco1366
pop the cover that goes around the shifter and one end of the cable is there, push clip style
Old Jul 11, 2013 | 12:05 AM
Car: 1992 Camaro RS
Engine: 305 V8
Got it fixed, but why is there two cables in there, lucky me the clip came off and all I had to do was push it back on
Old Jul 11, 2013 | 02:22 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Steering lockout
Shifter has to be in P before you can take the key out of the Ign switch
Old Jul 11, 2013 | 05:36 AM
Car: 1992 Camaro RS
Engine: 305 V8
Originally Posted by vetteoz
Steering lockout
hmm thats the thing, this cable was stuffed way back under the dash, and the ign worked as it should
BRoss99
Aug 10, 2025 05:08 PM
1992rs/ss
Jan 31, 2025 05:10 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TheExaminer
Aug 26, 2015 04:59 PM
