Ratchet Shifter - Gear Selection Lights
Old Jul 6, 2013 | 11:24 PM
illconductor's Avatar
Hi, I've just installed a B + M megashifter on my turbo700, and it would be nice to know what gear its in by some lights on the dash. SO what I'm trying to get is some kind of counter so when you hit it up through the gears 1 light comes on then 2 then 3 then 4. Anyone done this before? Any help would be much appreciated. Thanks in advance!!
Old Jul 7, 2013 | 01:20 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Ratchet Shifter - Gear Selection Lights
Lokar makes dash mounted LED indicators. Try Summit or Jegs.
Old Jul 7, 2013 | 03:54 AM
thanks for the quick reply, its so awesome how there is so much specific information by the members here.
third gens are awesome.
well im still looking at summit to see if there are any variations on what ive seen but basically that part you refer to only has pnrd21 where as my auto is modified to be pnr4321 so the display doesn't suit.
thanks though.
Old Jul 7, 2013 | 04:03 AM
well I just saw one for the t700 and it is p r n od d 2 1, which is close enough, I just wonder if it will work with my modded 700. and it says to hok the controller into the cars ecm I think which im not sure about...
Old Jul 11, 2013 | 02:24 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Not for a T700 /4L60.All the ECM controls is the lockup.
If however you had a 4L60E then it might do something because the PCM controls the shifts
Old Jul 14, 2013 | 02:16 AM
Thanks mate.
Dialed_In
Aug 20, 2015 01:45 PM
tnrednneck
Aug 13, 2015 08:57 AM
mizz0313
Aug 12, 2015 06:45 AM
Omega
Aug 10, 2015 12:46 PM
