7.5" spider gear thrust washer
Old Jul 25, 2013 | 07:56 PM
Steve30's Avatar
Car: 84 camaro z28
Axle/Gears: 4.10
Anybody ever try to track down a replacement thrust washer for the spider gears? GM makes you buy the whole gear kit. The only aftermarket supplier I found that has them is Yukon gear. So I ordered one and it was smaller than the one I took out of my camaro. I had them send another in case they packeged it wrong and I got the same thing. So does anyone know where else I can get one? Or should I use what I bought? The hole where the shaft goes through is the se size. The new washer does seem to sit better on the gear however; Seems to stay in place better. Also, just to clear it up in case anyone asks if I'm sure which rear I have, I verified my car has a 7.5 (2.73) by giving the dealer my vin. Any advice or thoughts are welcomed. Thanks in advance.
Old Jul 25, 2013 | 08:06 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: 7.5" spider gear thrust washer
Wrecking yard.
Old Jul 25, 2013 | 08:13 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Old Jul 25, 2013 | 08:26 PM
big gear head's Avatar
I've probably tossed about 100 of them in the scrap metal pile. I've got a small stack of them in my shop, but I have no idea which one you need.
Old Jul 25, 2013 | 08:34 PM
Engine: TBI,5.0
Old Jul 25, 2013 | 10:14 PM
Steve30's Avatar
Car: 84 camaro z28
Axle/Gears: 4.10
I need the one for the gears which the pinion shaft runs through. Not the side gears. Not sure if that clears things up or if you need to know the thickness. I have no clue on that though.
F-body driver
Mar 6, 2023 11:44 AM
Bohemian
Aug 15, 2017 05:11 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
88rscamar0
Sep 23, 2015 09:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
