GEARBOX SHIFT POINTS
Old Jul 31, 2013 | 06:10 PM
DAVID J BROWN's Avatar
Car: 1992 RS 25th ANNIVERSARY EDITION
Engine: 5.0L
Transmission: 4 SPEED AUTO
Axle/Gears: ALL OF THEM
Are the shift points adjustable or is it controlled by the ECM.
On mine, 1st to 2nd is almost instant, as soon as i touch the throttle.
Old Jul 31, 2013 | 06:14 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: GEARBOX SHIFT POINTS
No it is controled by the TVR cable to the Throtle body yours may need adjustment.
Old Jul 31, 2013 | 06:36 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Also controlled by the governor
Old Aug 1, 2013 | 06:01 PM
Engine: 5.0L
My wifes the Governer, she knows nothing about Camaros.
Old Aug 1, 2013 | 06:06 PM
Engine: 5.0L
I see, this might explain why i have no kickdown.
Old Aug 1, 2013 | 06:13 PM
morgsie's Avatar
WRONG! Do not listen to this it is NOT CORRECT. Shift points are determined by the shift valves in the valve body in conjunction with the governor for WOT shift points. TV cable should be tight at WOT, maybe 1 click (1/16") loose if part throttle is shifting slightly late.
Here is a good read: http://www.jakesperformance.com/TV_C...etup_Info.html
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
