9 bolt pinion removal
Old Aug 3, 2013 | 09:23 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I am looking to remove the pinion from my spare 9 bolt housing. The carrier is out of the rear. The entire rear is out of the car. I'm pretty sure the pinion gear comes out by hitting the thread end of the pinion with a lump hammer with a block of wood to protect the threads? This is correct, having trouble getting it out.
Old Aug 3, 2013 | 10:41 PM
excessiveego's Avatar
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
Re: 9 bolt pinion removal
leave the nut on the shaft, at the end, so that you hit the nut rather than the threads. Also, try a dead blow hammer first, if that isnt enough use a sledge but make sure you hit it square.
Old Aug 3, 2013 | 10:42 PM
big gear head's Avatar
Yes, that should work. I use a chunk of aluminum instead of wood. Have you already removed the yoke? The pinion will come out easier with the yoke removed. You can put the nut back on the end of the shaft to help protect the threads.
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
hectre13
Aug 26, 2015 08:17 AM
89fast5oh
Aug 24, 2015 08:14 AM
3rdgenparts
Aug 8, 2015 07:09 PM
