700r4 problems
Old Aug 29, 2013 | 11:01 AM
Lockhart88Iroc's Avatar
Car: 2004 Chevy Malibu/1988 Iroc Z
Engine: 3.5 v6 Malibu, and 305 camaro
Axle/Gears: 3:45
700r4 problems
I have a 700r4 modded by monster transmissions in Florida in my 88 iroc, it's vibrating at higher speeds and sometimes even lower speeds higher rpms will do it, it usually comes in an almost wavelike pattern except at higher speeds where it steady. Also sometimes it does weird stuff while I'm driving, like make a random noise. A small clunk or a little grind sometimes. I'm definitely not a transmission person. Anyone know what the culprit might be? And what I'm looking to spend to fix it? Or if I could fix it (I wouldn't hold my breath on that haha)?
Old Aug 29, 2013 | 09:42 PM
joshc's Avatar
Car: 1986 Trans Am
Re: 700r4 problems
How are you sure its the trans?
There have been a lot of vibration threads that ended up being a drive shaft or wheel/tire issue.
Old Aug 30, 2013 | 03:33 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: 700r4 problems
Was about to say the same thing. Also could be a broken tranny mount causing rattles. Check out the u joints first
Old Aug 30, 2013 | 08:52 PM
1983Zsled's Avatar
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
Re: 700r4 problems
What kind of tranny mount are you using? I used to have a polyurethane one and I had those same issues. I put in a stock rubber one and it was all gone. Acted like a different car......
Old Aug 30, 2013 | 09:17 PM
Pro Built Automatics's Avatar
Re: 700r4 problems
"it usually comes in an almost wavelike pattern except at higher speeds where it steady. Also sometimes it does weird stuff while I'm driving,"
I have seen this as a tire issue a few times over the years. This could be a possible cause.
Old Aug 31, 2013 | 07:59 AM
Axle/Gears: 3:45
Re: 700r4 problems
Alright I'll comb through them, thanks
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
