Did GM ever put Corvette transmissions in the IROC Z 350 cars?
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
Did GM ever put Corvette transmissions in the IROC Z 350 cars? Joined: Jun 2000
Re: Did GM ever put Corvette transmissions in the IROC Z 350 cars?
and if you mean an S6-40 ZF6 speed, the answer is no except for the LT5 camaro and the cars SLP did.
Have you ever gazed upon a S6-40? These things are HUGE, thje shifter is further back than stock and can't be moved and the clutch slave is interfering with the floor. furthermore they are set up for a dual mass flywheel and a pull clutch and a spingless hub oh and parts and repairs are stupid expensive. Then again, they shift like butter. I love the ZF6s I have a whole lot more than the T56s.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
well, they only put autos behind the 350 in F bodies.. the 700r4 probably used the same case in the Vettes as the F bodies, with only the tailshaft and a few internal pieces being different...
so the answer is "mostly"... unless you were talking about the ZF 6 speed or the 4+3 manual transmissions, then the answer is "no"..
But... but.... but........... the seller TOLD ME it was "out of a Vette"!!
{which I know for a fact, as I watched him go out to a derelict parts car he had in his back 40, open the door, and pull it out of the back "cargo" whatever you want to call that back there behind the seat, which proved to my own eyes and would hold up in a court of law that it was in fact "out of a Vette"}
Car: `86 SS / `87 SS
I know, I have 1 set up in my old race car with a springless hub and a non DM flywheel from a 4+3 vette...it makes quite a racket LOL That's why I wouldn't recommend it to anyone. I'm also using an LT5 pressure plate and a longer ball stud on it.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Iroc8t8
Aug 26, 2015 08:14 AM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
