Doesnt Shift Right After Oil Change
Old Sep 13, 2013 | 10:34 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Since my car was sitting still for 2 years after the transmission was rebuilt, I decided to change the oil on the transmission. But after i put everything back together it doesnt want to shift correctly? Reverse works ok, but when i put it in gear it seems likes its in second gear and i have to give it enough gas for the next gear to kick in? The only thing i did different is, put a new poly mount, and added the magnetic donut from my 4l80E onto the 700R4 Pan. Used dexron oil and 3/4 of lucas trans oil. HELP!
Old Sep 13, 2013 | 11:36 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Doesnt Shift Right After Oil Change
I know it's about as tempting as picking your nose to some people to add stuff that isn't necessary based on snake-oil marketing. But a newly rebuilt transmission has no benefit from Lucas. Think of it this way: Anything outside the norm just adds another element to the troubleshooting.
Is the bellcrank @ the drivers side of the pan fully reaching the 1st gear detent?
Did it ever work in 1st post-rebuild?
Old Sep 13, 2013 | 01:38 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
After it was rebuilt it ran fine. No problems. It just needed an oil change. And is the bellcrank the cable that shifts the gears? If so it goes down to first and all the way up to park. It is also a bit over the fluid level, but nothing serious. But will the magnetic donut from my 4L80E be affecting it?
Old Sep 13, 2013 | 02:32 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
The magnet will not affect anything.
It almost sounds mechanical. Usually those types of issues are associated with lack of fluid pressure. Did you do a filter change? Did you seat the filter properly?
Old Sep 13, 2013 | 03:55 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Hrspwr, yes i did a filter change, removed the old o ring, installed new and it seated properly. Im going to take off the pan again today or tomorrow, but I just figured and get some input before i go and start removing bolts.
Old Sep 13, 2013 | 04:06 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
If nothing else was changed or removed other than the fluid, pan and filter, it sounds like theres not enough fluid OR the fluid pressure is not building up as it should. Maybe a long shot, but try a new filter....possibly it is collapsed and not allowing fluid to be picked up.
Old Sep 13, 2013 | 07:44 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
I just took off the pan, nothing out of the ordinary, the only thing I can think off is a little bit of anti seize made contact with the oil? the magnetic donut? napa trans filter? lucas oil? Im gonna go to GM and get one from them and new oil to it
Old Sep 13, 2013 | 08:18 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Make sure the filter has the correct length tube.
Not too long ago a member got filter with a too short tube.
Old Sep 28, 2013 | 10:38 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
So what happened was that I made 2 rookie mistakes. 1 - I went off the manual and it suggested to use 5 quarts, but I had to use 9! 2 - I wasnt checking the oil on a even surface . But i appreciate your guy's input!
Old Sep 29, 2013 | 12:42 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
It should only take about 4 qts
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
