Australian 9 bolt to 12 bolt driveshaft length
Old Sep 16, 2013 | 11:06 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Hey Guys. Quick question:
I have a 87 gta. It had a 10 bolt, drum, steel drive shaft.
I switched to a 9-bolt disc, with an aluminum driveshaft. I do not recall if the driveshaft fits just he 9 bolt or both...
I am now buying a strange 12-bolt (ordering today). I hear its a direct swap, except i need 93-97 lti brakes.
MY question is, will the aluminum drive shaft fit the new 12-bolt? Or must it be shortened? remember this is a 9-bolt to 12 bolt swap.
thanks -J
Old Sep 16, 2013 | 03:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Australian 9 bolt to 12 bolt driveshaft length
I went, 9 bolt to a 9" and used a stock length DS. I'm fairly sure yours will be ok. It would be best to ask the rear end supplier/ builder.
Old Sep 16, 2013 | 05:27 PM
Car: 1987 GTA
thanks.. they are idiots. I went through strange, moser and curry and nobody knows anything.. they are like catalog rears.
That being said I went with a moser 12 bolt. they say it is good to 900-1000hp easy. Strange said only 700 and they were worried about the clutches failing in the posi and gear noise. I am thinking and hoping moser uses better posi units.
I picked 12 bolt because it is a touch lighter and more efficient than a 9 bolt and it is a GM rear (not that that matters). I figure its not a bad choice. I almost went 9" and would have if the 700hp strange rear was the only 12 bolt option.
Old Sep 16, 2013 | 06:41 PM
TTOP350's Avatar
I wouldn't worry to much about the ratings, I've seen modified stock rears take a major beating with big power and I've seen stockers fail with a stock v6 5speed.
Your only saving around 3-4 rwhp by going with a 12bolt over a 9". You are saving some weight w the 12bolt unless your running a spool and aluminum center chunk in the 9".
Rear choice is a toss up, unless your spray n a 500 shot, on slicks, 7k clutch drop with a 6speed. Then you want a dana 60.
Just use the rear you want to and enjoy every day you can with your car.
Old Sep 16, 2013 | 08:41 PM
Car: 1987 GTA
yeah. that's kinda what I was thinking. Strange was just very tentative about their rears holding up... Moser wasn't..
Old Sep 17, 2013 | 07:38 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I had a 9 bolt and went to a Moser 12 bolt. The stock drive shaft was a tad to long.
Old Sep 17, 2013 | 08:29 AM
TTOP350's Avatar
I figured they used a pinion yoke that would make it work properly for a "bolt in" rearend. Guess not.
Old Sep 17, 2013 | 10:10 AM
Car: 1987 GTA
yeah, I think I got the upgraded larger yolk. they said I should.. so I guess i'll need shaft work or a new shaft, but I guess that's par for the coarse. I would rather it not break.
Car: 1987 GTA
i ended up with true track, no clutches or springs, so it wont break. or atleast is stronger than the strange unit. they said it wont chip or make noise.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
