Trans won't shift into 1st, 2nd &Reverse
Old Sep 30, 2013 | 11:23 PM
KDot's Avatar
Car: 84 Camaro Z28
Engine: 350 carb
Axle/Gears: Stock
I have a 84 Camaro with the stock 5 speed V8 carb transmission. It would not shift into 1st gear a few weekw ago so I replace the clutch with a new one to try to fix the problem now after installing the new clutch it won't shift into 1st, 2nd or reverse. I bleed the clutch a LOT thinking that's the problem but no luck! Please I need help!
Old Oct 1, 2013 | 07:36 AM
Re: Trans won't shift into 1st, 2nd &Reverse
Which did you use; a pilot bearing, or a bushing?
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
maroe624
Apr 16, 2017 08:29 AM
