Motive Gear Master or Super 10 bolt rebuild kit?
Old Oct 14, 2013 | 01:31 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I'm all confused... and Motive is too...
I know they have an upgraded kit with Timken bearings, I want that...
Jegs says that the only difference between master and super is super is timken bearings and master is not...
But there are different part numbers for kits with generic and with timken bearings...
On Summit, it says only difference between the 2 kits is that the Super has axle bearings, but master doesn't...
So I called Motive TWICE... First guy said the axle bearings ARE NOT timken, second guy said AXLE BEARINGS ARE TIMKEN...??
Holy crap....
I got axle bearings with my Axles, but if they are generic and they have Timken available, I'll upgrade... Otherwise I'll just buy the cheaper kit without axle bearings...
Anyone been through this headache before?
Thanks,
Rafael
Old Oct 14, 2013 | 03:19 PM
big gear head's Avatar
Re: Motive Gear Master or Super 10 bolt rebuild kit?
Don't mess with Jeg's or Summint when you buy rear end parts. Call Tom's Differentials or Randy's Ring & Pinion for rear end parts. The kits (all of the kits) that Summit and Jeg's sell are not very good. They are all just reboxed Ratech kits, which SUCK. Tom's and Randy's have much better kits.
The axle bearings will be Torrington, not Timken.
Old Oct 14, 2013 | 03:49 PM
luvofjah's Avatar
Otay, thanks for the advice.
It sucks when the people you're buying stuff from don't know their stuff...
Rafael
Old Oct 16, 2013 | 06:26 AM
luvofjah's Avatar
I am still going to look where you recommended...
Someone that knows what they are talking about did reply to my email, so I am posting info...
Good Morning Rafael,
Kits with the ‘MKT’ suffix are Master Bearing/Install Kits, and ‘SKT’ are Master Bearing/Install Kits that also include the axle bearings and axle seals.
Timken is the manufacturer of all the internal bearings and races of any bearing kit that we sell that has a ‘T’ suffix. Without a ‘T’ suffix the kits are mostly Koyo Bearing which is an original equipment manufacturer for most Japanese cars and trucks. The axle bearings we sell for most c-clip axle applications are currently supplied by INA which is a quality German original equipment manufacturer of bearings for Mercedes, BMW, etc. Seals are made by various quality seal manufacturers that include National Seal and Chicago Rawhide.
Thanks,
Tom Campion
Distribution Center Manager – Texas
Old Oct 16, 2013 | 11:23 AM
luvofjah's Avatar
I checked Randy's Ring and Pinion and all their kits are either Yukon or Koyo bearings... didn't' see any with Timken... Even the US Standard sets use Koyo...
Old Oct 16, 2013 | 03:20 PM
The Yukon kits have Timken bearings in them. They also have the super shim sets. Yukon kits also have 2 crush spacers in case you screw up the first one.
Old Oct 16, 2013 | 03:27 PM
luvofjah's Avatar
Crush sleeve or solid spacer?
Old Oct 16, 2013 | 04:52 PM
They come with crush spacers, but you can get a solid spacer from them too. I don't know if they offer a kit with the solid spacer or not.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
