help me decide guys!
Old Nov 1, 2013 | 02:59 AM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
I am about ready to put a trans in the car I pulled the v6 version of the 700 r 4 out of it and I have all the parts to put one back in should I Put a v8 bellhousing 700r4 in the car or should I go with the th 350 or th 400? what do you guys recommend? Any input is much appreciated
Old Nov 1, 2013 | 04:07 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: help me decide guys!
I believe this will be decided on what you want from your car and also how you drive. Remember when you decide that the TH350 and 400 have no overdrive.
Old Nov 1, 2013 | 04:12 AM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Yea I'm leaning real hard towards the 700r4 bc i got all the parts xmember etc and its got an extra gear and overdrive
Old Nov 1, 2013 | 04:28 AM
Edwardgp's Avatar
Engine: 454-350
You can build up the 700r4 to with stand more power.
Old Nov 1, 2013 | 05:05 AM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
I didnt know that. hmm thats food for thought
Old Nov 1, 2013 | 06:43 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
my vote is for a 1987 or later 700r4.you can't beat that great first gear and overdrive.
Old Nov 1, 2013 | 07:00 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
With the price of gas I would want overdrive. If you're strictly going to race it and need something cheap then I'd go with a TH400. Best of both worlds would be a 4L80E, but that robs some power and is a little harder to install. A rebuilt 700r4 (post 1987) would be my choice in your situation.
Old Nov 1, 2013 | 07:32 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
ok thanks guys. I am looking for one now so any help pointed in a good direction would help I dont care if its blown or not I was planning on redoing one just for kicks and grins. What is the best stage rebuild kit/ brand you think for my situation engine is a 350 bored 0.40 over with a 480 lift at .50 with an hei distributor weiand single plane intake a 750 dp holly and headman long tubes I am leaning towards an alto I assume I will need the lockup kit for the converter with no cpu and idk if i want a shift kit or not I got a hurst promatic 2 shifter I was able to fit in the car it worked well with the old trans.
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Street Lethal
Aug 14, 2015 08:25 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
