Leaking trans fluid.
Old Nov 9, 2013 | 01:46 AM
djjon76's Avatar
Car: '84 Trans Am
Hi all.
Any easy quick way to fix a small, but persistent leak from the below pic?
I am guessing this is the speedo cable connection.
[IMG][/IMG]
Cheers.
Jonno.
Old Nov 9, 2013 | 09:22 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Leaking trans fluid.
Yes just did this. I disconnected the speedometer cable at the transmission and pulled the bullet out of the transmission. Went to the local transmission shop and picked up the updated version. Reinstalled and all has been well.
Old Nov 9, 2013 | 02:29 PM
OrangeBird's Avatar
Car: 1989 Firebird
Crazy question I know , But , have you checked to ensure that the knurled ring that threads the cable to the black part on the transmission is actually tight ? And yes , you are correct , that is your speedometer cable .
If Adelaide is where I think it is , Do you guys have any transmission shops in AUS. that carry parts for American cars ?
Also , it will be helpful to determine if the fluid is leaking between the cable and the black part , or from between the black part and where is fits into the transmission itself ? depending on where the leak is , provided it isn't from the cable being loose , it could be an O ring has gone brittle and begun to leak ?
Old Nov 9, 2013 | 04:46 PM
djjon76's Avatar
Car: '84 Trans Am
Very good point Init4fun.... Will check if the ring is tight. We do have the shops, but it's usually not here in Adelaide, would be more likely Melbourne or Sydney.
Cheers.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
cstrobel65
Aug 15, 2015 10:19 AM
mizz0313
Aug 12, 2015 06:45 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Exxon Limited
Aug 9, 2015 08:13 PM
