B&M shifter install questions
Car: 91 GTA
Axle/Gears: 3:73
Step 4.
The shifter park lock cable is to be disconnected permanently and tied off to the side out of the way?
In place of the cable we now use a switch hooked up on the shifter?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: B&M shifter install questions
The B&M doesn't have that provision
Car: 82 Z28
Transmission: T400
You cut the 6 wire connector off the stock shifter wiring and connect the P/N switch and backup light wiring
to the 2 micro switches on the new shifter
Purple / green to the P/N switch
Green / blue to the backup switch
Tape the Org wire up to make it safe
Car: 91 GTA
Axle/Gears: 3:73
Thanks!!
Btw, is it normal for the shifter in rachet mode to recoil slow? I remember playing with it a few months ago right out of the box but it seemed to snap back faster.... Maybe it's the cold grease, it's freezing in my garage.
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
Its 20 degrees down here and my recoil is fast. How cold is it up there. Maybe wd-40 or maybe it needs broke in. The whole point is to have lightning fast shifts
Car: 91 GTA
Axle/Gears: 3:73
Been awhile since I worked on this thing. I had a cotter pin fly out and can't seem to find one missing... Wondering if this might have something to do with the ratchet being slow?? I'll try to pull up a pick from where it might be coming from.
84z96L31vortec
08-20-2017 12:16 AM
