rear end whining, time for a new rear end? help!
Old Dec 8, 2013 | 12:24 PM
94trouble's Avatar
This morning I was on my way to meet up to head to the local toy run. As I get off the freeway, a hear a loud, howling/whining noise. So I went to a friends put the car on jack stands and seen what was going on. It was leaking oil from the u-joint area, and when I grabbed the drive shaft and wiggled it there was some play from the part that enters the pumpkin. I didn't take the rear cover off, Just put some gear oil in it and got home in a hurry.
Now the diff never tried to lock up on me, the tires weren't chirping when I turned or anything. Just had that howl noise. I haven't been back under the car because I just got it home but the part that connects to the drive shaft into the pumpkin seems to be the problem. I haven't checked for metal shavings or anything, but is it time for a new rear end or is there hope?
Its a 10 bolt rear end if that matter. 91 RS with a 5.7 tpi in it. 6 speed tranny
Old Dec 8, 2013 | 12:34 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: rear end whining, time for a new rear end? help!
Sounds like its time 4 a rebuild. Slap some bearings and seals at it and it should be fine.
Old Dec 8, 2013 | 12:51 PM
94trouble's Avatar
That's what I didn't want to hear would it be better to rebuild it or buy a new rear end?
Part of me doesnt even feel like dealing with this car anymore. How much could I get for it as it sits? Interior is mint. Motor is fine just needs the rear end fixed
Old Dec 8, 2013 | 01:22 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
sounds like pinion nut may have worked loose-fairly common occurance with these axles,nut is in the yoke(part that enters the pumpkin)when this gets loose the pinon bearings back off,causing the pinion to be loose and mesh with the ring gear improperly-better take the cover off and check for chipped teeth or bearing particles.If no major damage found,could brace the yoke and retighten the pinion nut-not too tight or pinion bearings could be damaged-if not tight enough,bearings will turn on the pinion shaft and wear it.
Old Dec 8, 2013 | 01:59 PM
big gear head's Avatar
Either the pinion nut backed off or a pinion bearing went out. It seems like you don't have the experience to do this yourself, so you probably need to find someone with experience working on rear ends and have them fix it. It could be anywhere from $100 to $600 to fix it. Good used rear ends for 3rd gen Camaros are getting hard to find, but you might be able to find one.
Old Dec 8, 2013 | 02:54 PM
94trouble's Avatar
I don't even want to deal with this car anymore. I'm just going to sell it the way it is.
Old Dec 9, 2013 | 07:38 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
where are you?i have a good 3.42 rearend i pulled out of my car to install a forth gen rear with discs to match my vette wheels.
Old Dec 9, 2013 | 10:03 PM
94trouble's Avatar
I'm in federal way WA
Old Dec 10, 2013 | 07:49 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Shipping a 3rd gen 10-bolt is a pain. Common carriers require that it be on a pallet, hard for a buyer to do long distance. And it can cost $350-$500 per 1,000 miles of travel. In fact, it's cheaper to drive 1,000 miles and back to pick one up than it is to ship one, if you have the time. I know; I did.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
jharrison5
Aug 19, 2015 05:53 PM
novaderrik
Aug 10, 2015 12:44 PM
