Borg Warner 9 Bolt
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
Borg Warner 9 Bolt
Okay so I just got my hands on a Borg Warner 9 bolt rear end. I want to know all about these axles and research isn't really helping me. What are these things worth I was told they are becoming harder to find. The one I got is a 2.73 posi with disk brakes. And how strong are these axles?
Re: Borg Warner 9 Bolt
A 2 series one isn't worth much. Nobody that cares about swapping a rear, wants gears like that. Which is probably why you were able to get it, for what I assume was, "a good deal".
They are marginally stronger than the 7.5" 10-bolt, but not by a whole lot.
They are virtually ALL posi w disc brakes. Nothing special about that. If the brakes are the cast-iron Saginaw ones, then REALLY nobody in their right mind wants that.
The 9 bolt gear is actually a 2.77, not a 2.73. This will have a 2 series Borg Warner 4 pinion differential in it, which will not accept any gears other than the 2.77. You can not put 3.27, 3.45, 3.70 or any other gears in it.
Car: 1983 Z28
Engine: 385 Fastburn
Hope that helps.
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
Axle/Gears: ??????????????
wouldn't any disk be better than drums ?
No, unfortunately, reality is somewhat different from "ideal" in this case. The Saggy brakes have many serious design shortcomings that make them, AT BEST, maintenance-intensive, and USUALLY, completely non-functional. I wouldn't put em on any car I own. There are ways to at least get em to work somewhat, but they'll never be the equal of modern disc systems.
Engine: 4++,350 & 305 CIs
89 is the only year good disc brakes (pbr) that were put on the BW rearend.
Car: 1991 rs
Engine: 350 carb
Transmission: 700r
I got ya. Thanks. I guess my best bet is to part it out ?. and hopefully get enough to get a disk break setup.
Car: 1983 Z28
I agree that they will never be the equal of modern disc systems, none of the disc systems that came on these cars will be (I'd hope 30 year old technology wouldn't be at least! haha)
Car: 1992 Firebird & 2009 Nissan 370Z
Engine: 305 TBI
Transmission: W.C. T5
Axle/Gears: 4th Gen Posi, Disc Break/3.42
Just wondering if anyone can clear up something for me, somebody in the post above said that there aren't any BW 9 Bolts with anything other than 2.77.
I found this rear end on CL and am thinking about buying it.
http://dayton.craigslist.org/pts/4330957168.html
Can anyone clarify?
Can anyone clarify?
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
9 bolts could be had in a few other ratios such as 3:27, 3:45, and 3:70. The rear you posted on Craigslist looks like an ok deal as long as the posi is good and the backing plates are still present.
Engine: 305 TBI
http://dayton.craigslist.org/pts/4340581946.html
What do you think
Engine: 305, 355
I think your better off with the 9 bolt. $250 is a lot for an open rear and it doesn't even have PBR brakes. The brakes on the nine bolt will not cost that much and it is a stronger rear.
Engine: 305 TBI
Well since it is apparently a 3 series because of the gear ratio, what brakes would I buy. The guy has no info on the car it came from and I'm not sure what cars these came off of.
Engine: 305, 355
9 bolts usually came on higher end cars such as 5.7 GTAs or irocs. If it came out of an 89 it would have PBR brakes but any other year car and it would have the iron calipers like that 10 bolt you posted. I need someone else to chime in because I am not completely sure but your best bet would be to swap the brakes from your current rear onto that one. If the guy does not know much about the rear, that becomes a great negotiating tool.
Car: 1983 Z28
Yeah the brakes from your 2.73 axle should swap right over as long as you have all the parts. The 9-bolt posi will be a better axle than the open 10-bolt for sure. In fact it sounds like you'll have the exact same axle as me when it's all said and done.
It may be different on the '92 but on my '83 buying brake pads is super easy, because now that I have the 9-bolt (I think it's out of an '87) on mine the front and rear pads are the same part.
Engine: 305 TBI
Well currently I have a 10 bolt from an LS1 with big rear disc breaks, posi and 3.42s lol
But I have to downgrade back to a third gen and I'm trying to get best possible performance with 3rd gen rear end.
I bought new wheels and tires and they won't fit right on my 4th gen because of the extra 2in
Car: 1983 Z28
Engine: 305, 355
Well since 10 bolt brakes apparently fit onto a 9 bolt, your best bet would be to swap your parts onto that 9 bolt. Not sure how much you have in your fourth gen rear but you may be able to sell off extra parts and do this swap extremely cheap. Selling the posi unit and gears will make up the cost of the 9 bolt and selling the axle shafts and backing plates will net a few more dollars.
Engine: 305, 355
Whoops somehow I missed the ls1 brakes part.If I were you I would put up an ad to trade your ls1 brakes for a PBR setup. Ls1 brakes are desirable and someone might go for them. Otherwise search ls1 brakes on a nine bolt. There are a few threads were it has been done but I only skimmed through the posts.
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
