4th gen aluminum drive shaft question
Old Feb 19, 2014 | 12:43 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Looking for some feedback here.
89 L98 hardtop
Headers, exhaust blah blah
3.70 gears.
I need to change my speedo gears which requires removing drive shaft. Any benefit to a 4th gen aluminum piece over the stock steel one?
I haven't done the suspension stuff but will be over next winter.
SFC, panhard, etc.
Old Feb 19, 2014 | 12:56 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 4th gen aluminum drive shaft question
89 L98 hardtop
3.70 gears.
SFC, panhard, etc.
If you can get one for about $100 it is a nice upgrade over the stock steel one.
Old Feb 19, 2014 | 12:59 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Never mind. Did some searching. I'm saving my money. Lol
Old Feb 19, 2014 | 06:12 PM
It does help....
As far as "performance", I'd describe it as, about half a RCH above "just noticeable difference". For $100, I don't think it's worth that, alone.
But it DEFINITELY can reduce the amount of noise, vibes, etc. from the drivetrain.
If I could get one of the GOOD ones (LS1) for $100, I'd do it, personally.
Old Feb 19, 2014 | 08:36 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
I was looking on hawks. $150+ shipping. Not sure if it's out of an LT1 or LS1. Just says 4th gen.
Old Feb 19, 2014 | 10:18 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Mine didn't even last one launch at the track, I wouldn't bother.
Old Feb 19, 2014 | 10:52 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I like the aluminum 3rdgen shafts better.
Old Feb 20, 2014 | 06:57 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I have an inland empire aluminum one that has held up great this last year. Alsocure the vibration issue I having. I have an ls1 driveshaft for sale also aluminum.
Old Feb 20, 2014 | 12:14 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
No, no, no, hell no. The LS1 years are all thin-wall, cardboard damped light-duty parts meant to save a corporation money. Not last under an enthusiastically driven car. The LT1 years may be better but . . .
Absolutely. These were far heavier duty than the LS1 versions. I've seen one last in a 10 second pro-shifted BBC 3500lb car.
Aftermarket is a great way to go.
Old Feb 20, 2014 | 05:27 PM
You're right, my bad; I got it backwards.
Definitely avoid the ones packed - LITERALLY - with cardboard. The factory LITERALLY took a bunch of regular cardboard, like boxes, and stuffed it in there, for sound-deadening. What a joke.
Old Feb 21, 2014 | 12:48 PM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Are you talking about an aftermarket or OEM? I found a "OEM quality" aluminum drive shaft for the 1991 Firebird from a yard in CA online for $166 shipped. Is this worth it, or would an aftermarket be a better place to sink the money? I'm only looking to push around 300 hp max through it.
Old Feb 22, 2014 | 07:35 AM
TTOP350's Avatar
Worked just fine In the 92 Firehawks that make 375 HP and have a 6speed.
Old Feb 22, 2014 | 10:25 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Oh wow…this is the VERY FIRST TIME I've ever heard of the newer 4th gen drive shafts being weak. I always figured about any aluminum DS is a little weaker than any steel one…but cardboard?!?!
Well - I already have one of those 3 rivers ones...Can I like…heat it up and burn that stuff out? What happens if it ever gets wet?…will it throw it out of balance?
Get I'll just keep running it till it breaks...
Old Feb 22, 2014 | 12:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Dyno results for what it's worth:
http://ws6.com/mod-1.htm
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
