aussie t700r4 vs us t700r4
Old Jan 2, 2014 | 07:39 PM
calais215's Avatar
So guy looking at a 86 iroc to buy that is a rolling shell. I know i can get an engine easily enough in aus. My question is am i able to use a v8 holden commodore trans which is a t700r4 also. What are the differences between the two if any?
Cheers
Old Jan 2, 2014 | 10:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: aussie t700r4 vs us t700r4
Identical trans
( and most on here wouldn't know the answer anyway , having never seen a Holden )
Old Jan 2, 2014 | 11:34 PM
IrocRoadRacer's Avatar
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
Cheers
Because of the Coriolis effect, the Aussie 700r4 turns backwards compared to the U.S. 700r4.
Old Jan 3, 2014 | 12:04 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
vetteoz is right, most of us probably wouldn't know. One thing that's popular over here is to swap the 305 and 700r4, for a 5.3 LS truck motor and either a 4L60E or even a 4L80E. So you might have that option as well. The advantage of the E version is that you can program it alongside the 5.3. The 4L80E would take some modifications though.
If you want to stick with the 700r4, the post 1987 versions are supposed to be better. IIRC you can tell by differences in the pan and by a number on the pump.
Actually here, this may help:
https://www.thirdgen.org/replace-700...c-transmission
Old Jan 3, 2014 | 01:06 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Got swapped at the same time as the steering wheel
Old Jan 3, 2014 | 01:14 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What you are going to need is a 3rd Gen tailshaft housing ( to mount the torque arm ) swapped on to any local T700 you use.
Edit
Alternative is make a custom crossmember with the torque arm mount like this
http://umiperformance.com/catalog/in...roducts_id=298
so you don't need the 3rd Gen tailshaft housing
Old Jan 3, 2014 | 01:19 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You are not limited to using a T700.
In the USA , there are crossmembers available to fit a TH350 or TH400
http://www.umiperformance.com/catalo...bdq3liis264de1
http://umiperformance.com/catalog/in...roducts_id=300
The torque arm is mounted off the crossmember rather than the trans
Locally I would just fab one up if you went that direction instead of the cost of importing one
Bull86
Aug 10, 2015 05:43 PM
IroczInOz
May 7, 2005 05:33 PM
jaykar
Mar 5, 2005 10:51 AM
bp91z28
Nov 17, 2003 08:58 PM
lukerene
Jun 25, 2002 10:16 AM
